adding nitrous to my HSR
Old Sep 15, 2019 | 04:55 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I had my new motor built to handle a 200 shot of nitrous. Any ideas on the perfect setup for it? Im just doing some research now. Motor is a forged 355 using the Holley HP ecm. I want a dry system so I need to calculate what I need for fuel injector size to run the nitrous. Im using ford 24lbs now. Also would you run a throttle plate or direct injection into the intake system? Or just a nozzle into the intake tube?
Old Sep 16, 2019 | 09:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: adding nitrous to my HSR
Based on what my motor looked like running a wet 150 shot thru a single nozzle upstream of the throttlebody, if you wanna spray 200, i would do direct port into runners. Distribution was an issue on my hsr
size fueling on a richer higher bsfc value like a boosted car for the total power you expect to make.
injector calcs using .48-.50 is common for na. .6-.65 for heavy boosted will give you margin on gasolines
Old Sep 16, 2019 | 06:26 PM
DIGGLER's Avatar
direct port would be best, but you might be able to get some crossbars into the plenum too.
Old Sep 17, 2019 | 03:37 PM
seiplentz's Avatar
Car: 85 Z28
Im def thinking direct port is the way to go. I think carb plates may fit between the upper plenum and lower intake on the HSR but im not sure.
Trinten
Mar 17, 2012 01:00 AM
89RsPower!
Oct 26, 2008 05:21 PM
Wishmaster's87IROC
Jan 16, 2003 11:45 PM
MelloYello
May 6, 2002 09:23 AM
Nitro Don
Mar 17, 2001 12:25 PM
