Fmic on ta
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Fmic on ta
Originally Posted by steve40
For guys running a fmic in front of the rad on a ta, are you seeing issues with heat soak or high temps.
Before I stored the car last year, I switched to a normal front bumper w/out the cut out I made, and surprisingly, it did not heat soak. Just remember to upgrade the other areas when you start making modifications. eg; Lower your fan settings, maybe consider a larger radiator, a cold air intake away from the block, a caged IAT sensor, etc.
Reuther m either in the intercooler or rad?
- Rob
Re: Fmic on ta
Have no idea what you mean by this, let alone what it even says lol...
- Rob
Damn auto correct on the phone, have to watch that!
Re: Fmic on ta
Thanks! I have a bigger rad and dual fans for cooling. Did you stand your intercooler up in front of the rad?
- Rob
Re: Fmic on ta
Do an AWIC. Less plumbing and better cooling.
http://www.frozenboost.com/
I would never supercharge anything again with an air/air intercooler. Worst idea ever. It would be one thing if someone made a "kit" for these cars, but since everything is custom anyway. I say do it right.
GD
GD
Re: Fmic on ta
GD
GD
Re: Fmic on ta
Water is a more efficient heat transfer medium. In fact it is 24.17 TIMES more efficient than air at absorbing and releasing heat.
The trade off for wiring a single 12v switched pump is 24x greater efficiency, plumbing with 1" hose instead of 3" pipe, and a much smaller radiator core. And the stuff from Frozenboost.com is excellent quality. Their customer service is great, and the stuff is cheap. There's no downside.
Ford, Chevy, and Dodge all use them in stock supercharged applications. They work for turbo's just as well. I honestly don't know why air/air systems are so popular. They suck.
GD
Re: Fmic on ta
When you swapped bumpers did you pull that duct out between the bumper supports and let it get air from under the car?
- Rob
