Nitrous Options from the gurus
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Had my new motor built to handle the spray. Looking at options for the right setup. Could I use 2 carb plates with the nozzles between my upper and lower intake on my stealth ram? Im looking at running a 150-200hp shot and what size injectors would I need for this? I have the Holley HP system so Im gonna let it control it as a progressive setup.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Nitrous Options from the gurus
You would need a specific plate for the holley intake as its an odd shape. Not sure anyone makes them. It isnt a regular carb plate
a nitrous nozzle upstream of the throttle body would be easiest and likely cheapest but Keep an eye on the distribution/plugs
injectors are gonna have to be sized based on total hp expected and desired duty cycle
Car: 85 Z28
I called nitrous outlet. They recommended the LT1 kit. With the plate at the throttle body. I wouldnt be using the fuel solenoid. I might pull the intake and drill and tap each port for jets. Not sure how far I wanna go. Lol.. My motor is expected to have 400HP +200HP with the nitrous.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
keep in mind:
-colder spark plugs
-fuel pressure safety switch
- reading spark plugs
- purge solenoid and filter
- fuel pump/system/line size
-colder spark plugs
Car: 85 Z28
My ecm can be set to monitor fuel pressure
Im running a walbro 255 pump but stock size fuel line.
I plan on running a purge valve.
Car: 89 Iroc-z
Transmission: TH400
255 should be enough fuel
single throttlebody plate is probably good even tho its designed for wet flow with fuel. Using it as a dry shot im not sure how that all works.
but dont matter i guess, as long as you tune to account for it.
i assume you set up an enrichment table that activates when nitrous activates, probably on a wot switch? 42 lb injectors may cover it
for simplicity's sake i would probably run a plate behind tb or nozzle before it. since running a dry shot, might even be able to modify the fuel spray bar to be a 2nd stage....
