Procharger problem
Old Dec 28, 2020 | 10:04 AM
Tarizza's Avatar
Procharger problem
Hi, in my 1991 Camaro I have p1sc procharger, but my tial bov not open at idle...
I have pressure in throttle body hose to bov, but not have vacuum... what is the solution?
Thanks!
Old Dec 28, 2020 | 10:57 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Prochrager problem
Always hook the BOV after the throttle body blades, not before. Tee into a source back by your fuel pressure regulator and try your test again. The BOV opens under vacuum, not boost, so hold a vacuum gauge on one hand and open/close the throttle with the other while filming. Depending on the spring being used, you'll target Hg just above idle vacuum...
- Rob
Edit: Nice choice with the BOV by the way...
Old Jan 1, 2021 | 04:09 AM
Tarizza's Avatar
Re: Procharger problem
Tanks you, In the rear of plenum I have the correct vacuum.
Mastiff
Apr 8, 2016 10:56 AM
bijjincam88
Jun 26, 2011 06:47 PM
AndrewSyndrm
Apr 19, 2009 12:46 AM
oifish
Jan 1, 2006 06:34 PM
