misfire under acceleration
Old Jul 30, 2024 | 07:07 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Recently the car started misfiring under boost.Ran perfect before. Runs fine NA and very mild boost. Above that, starts misfiring badly. Its a vortec 5.7, two GT35's and max of 10lbs of boost. I run an EBL Flash 2 and tune is solid, done by Rob (Street Lethal). Fresh plugs (TR6 GP) gapped at .028, good wires, FP is 38 lbs at the rail at idle. Only thing I can think of is my Racetronix pump going away or the parts store distributor any thoughts?
thx, Brian
Old Jul 31, 2024 | 10:59 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: misfire under acceleration
thx, Brian
Is there anyway you can take a log of fuel pressure under boost?? Without that you're kinda just guessing. Don't hear any too many guys running a TR6 projected plug for boosted setups most guys use the colder non projected plug BR7EF
Old Aug 1, 2024 | 06:47 AM
brian p's Avatar
Car: 86 IROC
Thanks for the idea on the plug. I was running the TR6 because its one range colder than the OE TR55. I thought that was enough but if that solves the problem, that'd be cheap and easy.
Right now, I have a mechanical gauge at the rail but don't have a way of data logging fuel pressure so you're right i'm just guessing.
Old Aug 1, 2024 | 06:55 AM
thatsupnow's Avatar
No problem. Maybe try the different plug and if you can just setup your phone camera where it can see the mechanical gauge to record fuel pressure. I mean that's probably as close to a log as you'll get. Or you know step up to a Holley unit. Lol
Old Aug 1, 2024 | 07:18 AM
brian p's Avatar
Car: 86 IROC
I'll borrow somebody else's phone for that experiment, lol. Or cover mine in header wrap... I just looked at some datalogs before it started acting up, everything under boost; spark, fuel, temp, was perfect, figures. I'll post back when I figure it out. Good time for our dollar to tank.
Brian
Old Aug 1, 2024 | 01:16 PM
thatsupnow's Avatar
Brian
Use a GoPro if you have one. I've used mine for various things in the engine bay while I was driving
stahrman0612
Sep 23, 2011 10:35 PM
Stephen
Jun 11, 2008 02:53 AM
91ChevyRS
Jul 11, 2006 03:40 AM
Wootah
Aug 26, 2004 11:58 AM
CrispyClutch
Mar 23, 2003 11:37 PM
