weiand 177
Old Feb 4, 2002 | 12:01 AM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
weiand 177
I WANT TO MAKE 500 HP on my engine..this the set I plant to have. Please advice
Please revise this set up. What is in blue is what I plan to change:
GM 355 (.030 Over) 2 bolt main with STEEL CRANK with "BEEFIER CON ROD"
I have heard that 2 bolt main is fine for this application??
Trick Flow Twisted Wedge Aluminum Heads (62 cc)
CHANGE SPRINGS, HAVE 3 WAY VALVE JOB
Forged Dish Piston with Molly Rings (about 8.0:1)
GM ZZ3 Hyd. Roller Camshaft ( 208 Intake, 221 Exhaust, and 112 Lobe separation)
Crane Roller Rocker Arms (1.6 Ratio)
Is the 1.6 ratio adversely affect the system??
Edelbrock TES Headers with a 3 inch collector, Flow master Cross Flow Muffler
Jet Performance Re-calibrated Q-jet.
Mallory CD Hyfire VI Box, with Mallory Comp 9000 Vacuum Advance Unilite Distributor and Coil.
Stock Pump, water system,
T-56 Borg Wagner Transmission, and GM STOCK 12 Botl Rear end.
All this on a 1987 Chevy Camaro.
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
TexasMaro
Sep 15, 2015 06:50 PM
R3500
Sep 8, 2015 10:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
