BlownBird, Guido, others with single planes and possibly minirams type intakes w/in
Old Feb 12, 2002 | 04:59 PM
Dan W's Avatar
I'm getting my single plane intake set up and was wondering where you guys put your regulator... I'm running an Aeromotive external (non rail mount). Pictures would be great if you have them. Thanks
Old Feb 12, 2002 | 10:18 PM
Guido's Avatar
Car: 2000 Trans Am
I dont have mine plumbed in yet, but you can see where I had it with my mini ram before here:
http://home.webworks2000.net/guido/fuel.html
Old Feb 13, 2002 | 06:44 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeo Guido!
Whats this thing in the discharge peice on your old 406??
Attached Thumbnails BlownBird, Guido, others with single planes and possibly minirams type intakes w/in-406front.jpg
Old Feb 13, 2002 | 11:39 AM
Guido's Avatar
Car: 2000 Trans Am
Its called a blowoff valve or bypass valve. Same thing different terminology.
Its used in the instance that you are at WOT and you let off the pedal closing the butterflies. The boost has no where to go since the engine rpms are up, and the blower is spinning. It lets the pressure off so it doesnt load up in your compressoir and blow out bearing seals.
Old Feb 13, 2002 | 11:46 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Interesting.. Whats it sell for??
Sounds like a viable thing..
-- Joe
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
