What would be the best Nitrous system for me?
Old Feb 24, 2002 | 08:39 PM
92 Z-28's Avatar
I have a 1992 Z-28, with the stock 350 TPI. I was just wondering which brand of nitrous would be the best, and how much would it cost? It will most likely be a 100 shot.
Thanks for your help
Old Feb 24, 2002 | 09:01 PM
HotZ's Avatar
I think that you should get a Venom Performance kit. It is a dry kit that is computer controlled that ties into each injector. So when it senses that your at wide open throttle it uses the nitrous. When your at wide open throttle it pulses more pul into the enigne so you dont run lean. When it senses you run lean it cuts off the nitrous. This basically a very easy kit to put on it is all color coded. Its very basic if you have never put a kit on a car. The kit runs about 625.00 basically the price of a regular kit but it is worth every pennie of it. I have put it on a buddys 2001 Cobra we have used it for a while and no probelm. Hope this helps.
Old Feb 25, 2002 | 12:24 PM
92 Z-28's Avatar
Thanks for the info. I will look into it.
Old Feb 25, 2002 | 02:42 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I won't deny its worth every penny, but you can get a NX kit that's easier to put on for $460.00. If your only spraying a 100 shot why bother spending the extra $$$ ? Thats $165 in you pocket you can spend on addons for your N2O.
Old Feb 25, 2002 | 06:34 PM
HotZ's Avatar
Ya but most likely you will prbably spend that money to a chip. Becuase with a kit like that the computer wont give more fuel when it sprays. Then you will end up spending that money on a chip. Seee what I am saying. The Venom I think is one of the best kits out there.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
