Twin turbo and emissions?
Old Mar 5, 2002 | 12:54 AM
Timmys88Z's Avatar
Ok, I asked if I could keep emissions equip. AND do the TT, answer was yes, anything can be done.
However....
How would I do the A.I.R. stuff? When getting custom downpipes and exhaust could that easily be incorporated into the plumbing?
Old Mar 5, 2002 | 05:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont see why not. just make sure the AIR fittings are still connected and injecting at each exaust port (by welding them to the header if needed, and your AIR line should still be going to the converter.
Old Mar 7, 2002 | 07:30 PM
Timmys88Z's Avatar
another one..
can I have the downpipe fitted for an 02 sensor?
Old Mar 7, 2002 | 07:47 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Yes, the two T3's I got from the junkyard are already threaded and set up for an 02 sensor. If you end up with turbos that don't have that, just weld in a bung for it. Just try to keep it pretty close to the turbo.
Old Mar 8, 2002 | 01:38 AM
Timmys88Z's Avatar
so the O2 bung was on the turbo itself?
Old Mar 8, 2002 | 06:52 AM
Car: 86 Cutlass
On the T3's I have it is. Its on the exhaust elbow after the exhaust housing. Not all turbos have that though. The turbo on GN's does not have this for example. The 02 sensor is actually right before the turbo on these. It really depends on what turbo you get.
cheesehomer
Dec 31, 2015 08:48 AM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
