high idle after installing plate
Old Mar 5, 2002 | 05:06 PM
bandit45's Avatar
I just installed my nitrous plate under my throtle body of a tbi. I have a edelbrock open element on top. My problem is the car idles at 3 grand right off the bat. When i put it in reverse it kicks stones everywhere. I figured it was a leak so instead of using mr gasket i scraped off that crap and used a real gasket on the plate, but i still have the problem. My breaks arn't working at slow speeds either anyone have any idea???
Old Mar 5, 2002 | 05:15 PM
82resto's Avatar
HUGE vacuum leak.... did you torque all your bolts correctly?
Jon
Old Mar 5, 2002 | 06:27 PM
maniacc's Avatar
Check that your throttle cable is allowing the TB to close all the way. It's something that can be simply overlooked.
later
larry
Old Mar 6, 2002 | 01:34 PM
chevyboy07 91's Avatar
same thing happened to me when I did my nitrous on my previous 91 RS. When I took the TB off to do the free mods and plate, I disconnected like 3 (i think ) of those 90 degree vaccum hoses. The one on the back I forgot to put back...that was my problem and an EZ fix. So, check that and see if its it. There might even be 4 of those hoses (cant remember)
Old Mar 7, 2002 | 08:44 PM
bandit45's Avatar
Welp I finally got it fixed, I completly removed the throttle body and used plenty of gasket maker. I could have made any of those mistakes but redoing the whole process fixed something. My second time i did forget the line in the back thanks for the reminder.
customblackbird
Aug 15, 2021 10:16 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
camaro71633
Sep 1, 2015 10:24 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
