Turbo Charger
Old Mar 13, 2002 | 01:34 AM
PimpCamaroRS's Avatar
Turbo Charger
alright guys i think i wanna do it and make that step towards Turbo chraging my engine. I dont realy know where to start, does any one one wanna give my some prices, types, power increases and things like that. Also is there a special kind of rearend you haveto get to take this kind of power or mess with the computer at all? sorry guys i need to learn tho.
Old Mar 13, 2002 | 08:47 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Read Maximum Boost by Corky Bell and Turbochargers by Hugh Macaiines. Do a search on this board, you'll find lots of info.
Old Mar 13, 2002 | 10:45 AM
i have been searching but can notreally find much info. What i want to know is with a 400hp motor i am dropping in soon, do turbo charger require any special thngs on the engine, or is it jut hook it up burn a chip then ur ready? Also i know my 10 bolt wil barely hold up to my 400 HP so i there some thing i ave to do to my rear end or should i just go to 12 bolt, if so where can you find one?
Old Mar 13, 2002 | 05:01 PM
Car: 86 Cutlass
Before I can help I really need to know more. First off, whats the compression ratio of your engine? Thats going to help determine how much boost you can run. Is this carbed, TPI, TBI what? When running boost you have to make sure that you have sufficient fuel, otherwise bad things happen. This means you really need to have a good fuel system. I could probably keep going, but I need more info.
Oh yeah, you'll most likely break the 10 bolt if you hook. As far as finding a 12 bolt I think there are ads in the back of car mags for 12 bolts for F-body's.
Grant2k
Apr 4, 2016 08:21 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Formula_88AE
Sep 3, 2015 01:47 PM
