just some more ProCharger Questions
Old Mar 23, 2002 | 10:17 PM
onebinky's Avatar
I am looking into adding the procharger setup with the P600B to my car. The first problem is that my car is TBI. I have read that an airbox is available that will adapt the TPI setup to either a carb or TBI. I have searched and cannot find any pictures or part numbers online. Also, I am assuming that I will have to upgrade my fuel system. What size injectors and pump will I need? My compression is at about 9.3:1, What amount of boost can I realistically run on a stock bottom-end without detonation? Just the 9 pound pulley the kit comes with?
Thanks for any input,
Matt
Old Mar 25, 2002 | 06:25 PM
onebinky's Avatar
Nobody knows? If nothing else just answer the question on adapting it over to TBI!
Old Mar 25, 2002 | 06:37 PM
maniacc's Avatar
you can get the ATI tpi kit, and also get a TB bonnet for the TBI truck kit thru ATI, though you will probably have to do alittle fabricating, call ATI and they can recommend any injector upgrades needed.
You should have no problem running 9#'s on the stock bottom end as long as everything is in good condition, and the engine is tuned properly for the added boost.
later
larry
Old Mar 25, 2002 | 07:34 PM
onebinky's Avatar
Thanks for the info. I've also been searching for an E-mail contact with ATI, but can't seem to find one. Anyone know one?
Thanks again maniacc,
Matt
Old Mar 25, 2002 | 09:38 PM
sslee's Avatar
proddev@procharger.com
email chris he is very helpful from what i have seen.
Old Mar 25, 2002 | 11:08 PM
onebinky's Avatar
Thanks for the tip, I just emailed him. Thanks again for the help guys
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
