fuel pressure reg for nitrous?
Old Mar 25, 2002 | 09:10 PM
strokeronthesause's Avatar
anyone use those magnaflow regulators tell me what u think? my bg 2 port creeps too much!!!!!!!!!! junk!!!!!!!!!!!!!!!
Old Mar 27, 2002 | 10:03 PM
Kandied91z's Avatar
tpis is the only one i would use....
Old Mar 28, 2002 | 01:18 PM
im carburated dude!!!!!!!
none
Old Mar 28, 2002 | 01:22 PM
Metalifann's Avatar
Take a look at the regulators made by Aeroquip. Jegs sells them.
Old Mar 28, 2002 | 03:31 PM
bjm323's Avatar
Car: '91 Camaro RS
Get rid of that BG regulator. I have heard nothing but bad things about BG. There fuel pumps and regulators do suck. If it was up to me, I would look into getting a magnaflow or a products engineering regulator. Aeroquip makes a quality piece also.
Old Mar 29, 2002 | 07:53 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I hate fuel pressure creep so much that I will only run return style on cars we build, is that what you guys have?
Old Mar 29, 2002 | 09:47 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
b4ctom is right. Fuel pressure will not fluctuate so badly with a return.
Old Mar 29, 2002 | 09:52 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Hey, I just read your sig. You got a pretty fast ride. I am curious about the cam your running. I am thinking about a 383 in the near future. Also, what stall, gears, trans and tires you using to get you into the 10's
Old Mar 30, 2002 | 08:45 PM
goneracin's Avatar
Re: fuel pressure reg for nitrous?
The magnaflow regulators are very good pieces. The shop i work at builds some very high end stuff, and we use alot of the 4 port magnaflows. the 2 port should wour well also. By the way, thats a pretty good running 383 you got.
Old Mar 31, 2002 | 02:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the tires are 28x12.50x15 e.t.streets on 8.5" convo pros (they fit on the old 85 heaven help me if they won fit now). gears are 4.10s in a currie 9". the trans will probably be a th350 or 400 with a brake (that I will build for myself) and I will let the converter shop build the converter to spec. its they're job, who am I to tell them how to do it. I learned along time ago to leave things that are specialized up to the people that " specialize" in it. So I have a paint guy for paint, an interior guy for interior, a cage guy for real nasty chromoly cages and chassis (we do 8 points here ourself though), a CNC machinist for the special things, and a racer for our engine machinist. We do the concept, design, power, assembly, parts, dynotuning, and sales our selves just like everybody else. It is a professional relationship that produces "mad rides".
Old Mar 31, 2002 | 07:52 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I was really wanting to know about "strokeronthesauses" setup. But sounds like yours is gonna be fast also.
Old Mar 31, 2002 | 11:03 PM
cam and stall!!!!
cam is hr xr288 comp cams and the stall is a pro torque 2800(kept tight for shot)
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
