Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Forum Problem
Old Apr 22, 2002 | 10:10 AM
GRAHAM's Avatar
Forum Problem
I try to place an ad and it will not accept my copy...says jpeg image not found but I'm not trying to upload any image...that is also why I posted the ad in the chat room...
Old Apr 26, 2002 | 03:59 AM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
Try this:
Delete all of the cookies that are on your computer. Then, log back on to the classifieds and see if you can post.
If you use IE, you can delete your cookies by clicking on TOOLS>INTERNET OPTIONS and then clicking on the DELETE COOKIES button. Netscape should have a similar function as well.
Let me know if that helps you at all. If it does NOT help, let me know what browser and version of that browser you are running. Please send the EXACT error message the classifieds are giving you as well.
Old Apr 26, 2002 | 10:31 AM
Brad's Avatar
Do you use a Mac? IE on the Mac has a known issue where it submits garbage characters in every form field when you click the submit button. This causes servers to see "data" in all fields, even when some are left blank. This is normally not a problem because most servers see the garbage data as blank spaces, therefore not bothering the text that may or may not be entered in a conventional form field. However, on file upload fields, the server will see this garbage data as an attempt to upload a file, and will then attempt to process the data as normal. This always results in some sort of error. Use Netscape on the Mac to avoid this problem.
If you don't use a Mac, then proceed with Dirk's suggestions.
Armored91Camaro
Aug 25, 2015 12:01 PM
neekolzun
Aug 24, 2015 04:59 PM
hokis
Aug 9, 2015 03:57 PM
