classified ad problem
Hi all, I'm new to the board and I wanted to post an ad in the classified ad section. I log in and it welcomes me but then says I must log in or register to post to the board. What am I doing wrong?? Thanks in advance for any help.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
check your privacy level (on the privacy tab
) if you are using IE6, set it to medium and then try again.
) if you are using IE6, set it to medium and then try again. Thanks for the suggestion, I am using IE6, but already have security settings set at Medium as the default. I've tried with my WinXP, 98se and ME systems and still can't post in the classified section.
Any other suggestions?
Thanks again.
With Light,
SOS
Thanks again.
With Light,
SOS
Car: 99 Formula
Axle/Gears: 342
Tuesday, May 28, 2002
If you're having problems with getting logged out of the board and are forced to log in all the time, or if you can't post a Classified Ad or post a Readers Ride, do this:
Log in to the board.
Click on the USER CP link.
Click on EDIT PROFILE.
Make sure "Automatically login when you return to the site? (uses cookies)" is set to YES.
Make sure "Browse board with cookies?" is set to YES.
Then click on SUBMIT MODIFICATIONS.
Now would be a good time to DELETE YOUR COOKIES. After you log on again, everything should run properly for you.
If you still can't post a Classified Ad, then keep reading:
You are probably running a software firewall on your computer and you have "Browser Privacy" enabled (or something to that effect that hides your browser info and referrer info). Disable it. Go to the webpage that your software company maintains if you need help figuring it out. You can re-enable it after you're done posting your ad, but you'll need to disable it if you want to post again.
Those of you getting Error 502 messages all the time... it's nothing I can fix. The proxy server you are behind is overloaded and is giving you the messages, not thirdgen.org.
