Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Sorry! The administrator has specified that you can only do one search every 45 secon
Old Apr 13, 2004 | 01:10 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Sorry! The administrator has specified that you can only do one search every 45 seconds.
Dumb.
Old Apr 13, 2004 | 08:58 AM
JT's Avatar
JT
Community Administrator
It is an inconvenience, but it's needed to help keep the server load within normal operating ranges. If the server load goes too high, which can happen if too many people hammer the search, the entire forums will suffer with slow response and/or to the point of getting the Server Too Busy error at which point no one can use the forums until the server load returns to a normal state. The server already gets loaded down quite often as it is with this large board and activity.
Most vB forums have that flood check in place, some are set higher and some are set lower. Due to the size of this forum and it's rather large activity, it's higher than default value is needed at the moment until TGO does some upgrades.
That's my view of it, but I'm not a TGO guy. Dirk and Iroc are the admins.
Old Apr 14, 2004 | 08:19 AM
MdFormula350's Avatar
how about they disable the search all together
Old Apr 14, 2004 | 03:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That would be really bad. We would get the same questions every day like "what is a 350?"
Old Apr 14, 2004 | 08:14 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
or did any thirdgens come with a 350/5speed? but no one uses the search anyway and we get the same damn questions.
Old Apr 14, 2004 | 08:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
We force people to search by lcoking their threads. All of the stickys are helping immensly on the redundent posts.
Old Apr 15, 2004 | 11:00 PM
yeah i was just kidding anyway. they xx sec rule sucks but its needed for now at least.
Old Apr 23, 2004 | 07:44 AM
Dr G's Avatar
Originally posted by JT
..........It is an inconvenience, but it's needed to help keep the server load within normal operating ranges. If the server load goes too high, which can happen if too many people hammer the search, the entire forums will suffer with slow response and/or to the point of getting the Server Too Busy error at which point no one can use the forums until the server load returns to a normal state. The server already gets loaded down quite often as it is with this large board and activity......
Is there going to be anything done with the server to allow the search function time limit to go back down (in terms of minimum seconds between searches) at any point?
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
