email says inbox full, but it isn't
Subscribe
Jun 15, 2004 | 07:31 PM
I just got an email saying my inbox was full, but I only have 9 currently. It's nowhere near being full as before. What gives?
Reply 0
Jun 15, 2004 | 07:46 PM
Quote:
When you go into your Private Message section, what is your default viewing?
"Show Messages From:X days". This setting is near the top left half of your screen. Make sure you select the setting to something like "the beginning" to show ALL your stored private messages. If your setting is too low, you will not be shown any messages that older than the set date above, even though they still count towards your quota. Also make sure to check your sent folder as well.
I mention the above because I know it gets several people many times.
By the way, your default "Show Messages From:X days" when you log into your private messages is controlled through the same setting as your "Default Thread View:" setting in your user control panel under the Thread View options that controls how old of threads to display in the forums. Hope that makes sense.
Reply 0
Jun 15, 2004 | 07:51 PM
I have it set to "the beginning"
Reply 0
Jun 15, 2004 | 07:53 PM
Check your sentbox folder. I forgot to mention that, but edited my post just before you replied.
Your inbox is not the only folder that counts towards your quota.
Reply 0
Jun 15, 2004 | 07:54 PM
Also go down to the bottom of the PM page and you will see a button marked PM tracking. Click on that and it will show all the messages that you have sent. This is also stored in your mailbox and should be cleaned out every so often. That is probably why you got the INBOX full message.
Reply 0
Jun 15, 2004 | 07:57 PM
Actually, PM tracking does not count towards the user's quota. It is just a script that checks the database to see if a message was read or not. Any messages in that folder aren't counted, unlike the Sent folder.
Quote:
Reply 0
Jun 15, 2004 | 08:06 PM
Quote:
You're right, my bad. I was thinking about the sent folder and put tracking.
Reply 0
Jun 15, 2004 | 08:07 PM
Well I just deleted it all. There is nothing at all left so pm's should be fine now, lol. We'll see.
Reply 0
Subscribe
