Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Search Problem / can't search for Vacuum in Power Adder
Old Aug 18, 2004 | 01:11 PM
copperhead110's Avatar
I'm trying to search for "vacuum" in power adders and the search keeps failing. I've tried 4 or 5 times and different days. I either search in the evenings or during the day at lunch time. I'm in Pacific time zone.
Why would this search always fail? I usually get a DNS error from internet explorer.
Old Aug 18, 2004 | 03:09 PM
MdFormula350's Avatar
i ran the search and got 271 Topics. i took a few seconds longer that normal but worked.
does any other searching keywords work?
Old Aug 18, 2004 | 03:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you search for something that returns a lot of results, it will eventually time out and fail. Try searching for every post that RB83L69 has made and you'll see what I mean.
Old Aug 18, 2004 | 03:25 PM
JT's Avatar
JT
Community Administrator
The search was causing some load on the server, which is probably why it wasn't completing.
You might try the URL below to see if it helps, but it may not help in this case. The URL below will be valid for a while before it expires, it also will only contain the results up until the search, nothing newer.
https://www.thirdgen.org/techbb2/sea...der=descending
Infested
May 22, 2018 11:56 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
