Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
If JT's right, do that many people use email notification?
Old Oct 15, 2004 | 05:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Just curious as to if most people use email notification; seems like I can't reply to any post! That's gotta clog up an e-mail box pretty fast... and I get enough spam already. (laughs)
Old Oct 15, 2004 | 05:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Test of replying to myself!
Old Oct 15, 2004 | 05:48 PM
JT's Avatar
JT
Community Administrator
i'm fairly certain that it is email notification, but of course i could be wrong being on the user end. Beyond that, the Admins will have to figure out why the mail server is holding everything up.
You can reply to your own self because the software knows not to send you a reply informing you that you replied, regardless if you have email notification enabled
Old Oct 15, 2004 | 08:01 PM
CaysE's Avatar
interesting
Old Oct 15, 2004 | 08:02 PM
JT's Avatar
JT
Apparently no one in this thread (so far) has email notification on.
Old Oct 15, 2004 | 08:24 PM
FIREBIRD7777's Avatar
seeing if this works, just turned of my email notification
YEP thats what it is,, turn that off and reply works fine ..
Old Oct 15, 2004 | 08:30 PM
JT's Avatar
JT
i may not have understood you, but your ability to post is NOT just based on your own email notification setting. Of course if you have email notification on, you will currently make the thread unreplyable for everyone else.
Rather, it is based on if anyone *else* in that thread that you wish to reply to has the email notification on. If they do, you will not be able to post.
Simply you turning off email notification wile trying to post in a thread will not allow your post to go through if anyone in that thread before you post does have email notification on.
Hope this helps. i edited it to hopefully clarify it better.
Old Oct 15, 2004 | 08:37 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Mine is on, lets see...
If no one else can reply to this, that means I messed it all up
Edit- I forgot to check the box cause I'm a dumbass. Now its on though.
Edit- Its back off, since some people seem to think I'm doing it to be a smartass
Old Oct 15, 2004 | 08:38 PM
JT's Avatar
JT
You sure your "Use 'Email Notification' by default?" or "Email Notification:" is on?
If so, this is the first time i have seen it work.
Old Oct 15, 2004 | 08:43 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I usually disable it, but it seems to not be making a difference. My threads are going easy enough.
Old Oct 17, 2004 | 01:34 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I use it and my e-mail box is never flooded with replies...it will only alert u if someone replies to ur post but if more people reply to that post without u checkin the post first it will not send another e-mail until u have checked the post then while u are on the site and some replies then it will send u and e-mail again. Sou will only get one alert per thread. But just check ur inbox daily and u should be fine....just dont be a post ***** and u wont be flooded I use e-mail notif. and I love it!!
Jason
Old Oct 17, 2004 | 03:39 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The email notification seems to be disabled for the moment anyway.
Whats really weird is that even though I diabled all email notifications and unsubscribed to everything it still shows me as subscribed when I start a thread.
Old Oct 17, 2004 | 04:34 PM
JT's Avatar
JT
i think the feature has been re enabled, but if i am wrong, it should be safe to re enable as Dirk found the problem and corrected it on the server. The server is now sending mail.
Old Oct 31, 2004 | 06:30 PM
Dr G's Avatar
Re: If JT's right, do that many people use email notification?
I personally use the email notification service and find it great for keeping you up to date threads you might have otherwise missed. It's also good for when you don't wish to reply to a topic, but wish to see the replies to it, so subscribe to it by clicking on the appropriate link at the bottom of the page.
Whata69
Mar 2, 2016 06:34 AM
89newfun
Sep 16, 2015 09:28 AM
dementednut
Sep 10, 2015 09:50 PM
e3pres
Sep 9, 2015 01:51 PM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
