Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
HELP!!! can spybot stop my posting??!!
Old Nov 2, 2004 | 07:56 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
couldn't find the right place to put this thread so i'll put in the 'general' field.... i used to able to post and reply to threads at home from my laptop until i downloaded 'spybot search and destroy' from download.com and 'pop up blocker' from download.com. also i put 'macfee privacy' on my comp also... now i cant do anything but review threads and everytime i try and reply or post i get re-directed back to the log on screen!!??? i emailed the webmaster twice but no respone.... has anyone had this problem or is my laptop going coo-coo???? also, should my cookies be disabled or enabled??? THANKS all..... need help quick!!!!!:hail: :hail: :hail: :hail: :hail:
Old Nov 2, 2004 | 07:59 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: HELP!!! can spybot stop my posting??!!
Not sure about macaffee, pop up blocker shouldnt matter and yes cookies should be enabled.
Old Nov 2, 2004 | 08:01 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i forgot to mention, im fine here at work.. i can do all functions....
Old Nov 2, 2004 | 08:13 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if all you can do is look at the threads and when you go to post on one it takes you to the original page to log in that means your not logged in and you need to turn on your cookies so your logged in when you visit this site otherwise you need to log in when you come here every time...
try logging in and go from there...
Old Nov 2, 2004 | 09:02 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
from home i keep re-directed back to the log in screen... every time i want to post or reply! once i log in i should be logged in for good right? i should have to log in every time i want read, reply or post or send a PM.....
Old Nov 2, 2004 | 09:03 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i meant to say i shouldn't have to loggin for every thing i want to do like, post, reply or PM
Old Nov 2, 2004 | 09:08 AM
THEGENERAL's Avatar
no you shouldnt..
make sure your cookies are turned on
otherwise it could cause what your describing ..
spybot is a wonderfull thing but that along with the other things you have installed lately is obviously whats causing this and i believe it has to do with your settings...
Old Nov 2, 2004 | 09:38 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, i'll try it tonight when i get home......
Old Nov 2, 2004 | 06:14 PM
JT's Avatar
JT
Community Administrator
It is likely your McAfee utility is blocking the cookie through some type of privacy settings. i don't use McAfee, so i can't help a whole lot.
But it is for sure a cookie issue. It either is your McAfee via the privacy settings that is blocking the cookie from TGO, or it is a corrupt cookie on your machine. It depends on your operating system as to where your cookies are stored, but you may want to view your cookies and signally delete the TGO cookie. You don't have to delete all the cookies on your machine, and i'd recommend that you don't. You don't want to lose ALL your logins and preference settings for every single site you've visited. Once you delete the cookie, and you visit this site and log back in, you'll get a new one.
But i'd guess it is due to your McAfee program, so doing the above would be my second recommendation if you can't find any problem with the McAfee utility.
Try to disable the McAfee utility first, and give it a try.
Old Nov 2, 2004 | 08:39 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
it worked!!! i removed that privacy protection junk! thanks alot guys!!!!!!!!!
Old Nov 2, 2004 | 09:07 PM
JT's Avatar
JT
You did not remove SpyBot, though, did you? You shouldn't have to, and if you did, i would recommend you re-install it. Its a good program to have installed and use.
Old Nov 3, 2004 | 06:39 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
no, spybot is still installed...... i have to run it once a week though to catch all of those hackers!!!!
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
