Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Search Function's
Old Nov 19, 2004 | 03:06 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Search Function's
First off I would like to say HI. I have not been around fast cars for about 10 years. ( I had 2 kids.) Well now money is better and I just bought a 87 GTA Trans Am and found this forum.
I wish they had a place like this 14 years ago..
Anyway I have been looking through this forum for about 3 days now a just registered today. The main reason I registered was to use the search functions.
That is where I found a problem.
When I search for a code like CODE 21 it will not let me because 21 is only a 2 letter word. I can see what you would not want people searching for things like How can I tune a LB9 because words like I or A would kill your server. But the codes are all 2 numbers.
By the way I love the tech section at https://www.thirdgen.org/newdesign/tech/
I would love to know if you sell memberships or something for me to help support this site.
Old Nov 19, 2004 | 08:48 PM
JT's Avatar
JT
Community Administrator
You are right about two letter search words. They'd make the search database huge (gigabytes). It already is large as it is. It could also create a server load issue.
Since you seem to have an understanding, you may already know that when you perform a search, you really are not searching the data in the post fields. You are not searching the actual posts. Instead, you're searching through a search table that is linked to posts that contain the word you're looking for.
i'm sure TGO could have certain two letter words/digits (like trouble codes) included in the search table without having to include all two letter words that aren't already in the "bad" list that vBulletin contains to prevent people from using common search words (to, as, is, etc.) but since TGO wants to upgrade their software, i'm guessing TGO is not likely to go through that much trouble.
i think that issues like this should be less of an issue once TGO upgrades their vBulletin software and takes advantage of MySQL's full-text searching. i know that is Dirk's plan.
i am not aware of any type of memberships, other than perhaps supporting the sponsors above. But Dirk or Iroc (Admins) probably can answer that better.
Old Nov 19, 2004 | 09:36 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i cannot agree more with the search functions being funny in the way you have to word things ...
if you are looking for the codes and what they are you can find them here https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
just scroll all the way to the bottom of the page
Old Nov 20, 2004 | 07:17 AM
rawley2's Avatar
Thanks,
Now it off to adjust the throttle position sensor and get rid on one problem. I think the code 42 I'm getting is going to be a little harder than an adjustment.
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
