Clock incorrect
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Clock incorrect
Can someone please get the current time set correctly? It's not even close......
The server time is a little slow, but it is not extremely out of sync.
You may need to adjust the Time offset for your timezone if you show a different hour, since the server is located in AZ, and i believe it does not have daylight savings time. So the server's time zone compared to others, changes.
You can adjust your time offset in the usercp section under the Edit Options link. Below is the direct link. Scroll to the bottom.
https://www.thirdgen.org/techbb2/mem...on=editoptions
I can figure the hour part, but the minutes being either 15 or 45 off is kinda irritating...
Just my
Just my
.............. Thread
Eric-86sc
Feb 25, 2016 09:02 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
gta892000
Sep 16, 2015 12:37 AM
