Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
avater frustrations!
Old Dec 25, 2004 | 12:42 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Hello,I am trying to post a pic of mine on the old avator and I dont know how?Can somebody please help me?
Old Dec 25, 2004 | 12:59 PM
JT's Avatar
JT
Community Administrator
i'm a bit confused. You trying to post a picture in your message? If so, you can use these directions:
http://www.gtanotchback.com/misc/tgoimage.html
If you are trying to change your current avatar (the picture under your username), then do the following:
Click on the user cp button near the top right corner of your screen
Click on the Edit Options tab link
Scroll down to the bottom of that page and click on the Change Avatar button
Now, if the image that you wish to use is stored on your computer, simply click on the Browse button. A new window will open showing the contents of your hard drive. Find the image on your hard drive, and then click on it and OK/Open. Then click on the Submit Modifications button.
If your image is stored online, simply enter the URL path to your image in the box that has the http:// prefix text in it.
Please note the following (current) restrictions on avatars:
Maximum size of your custom image is 64 by 64 pixels or 20000 bytes
If your image is bigger in either way, you will need to edit your image to fit the above guideline, in order for the avatar to be accepted.
Old Dec 25, 2004 | 02:08 PM
Thanks JT,
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
