Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
why do i keep having to log in!?
Old Jul 18, 2005 | 04:00 PM
10sec 91's Avatar
Car: 91 z28
Engine: 383
Transmission: 350
Hello, i just joined this site but whenever i try to search forums or reply to a thread or whatever i keep having to log in at sometimes every other page.even whenthe main page says i already am. help!
Old Jul 18, 2005 | 04:44 PM
JT's Avatar
JT
Community Administrator
With an issue like this, the first two questions usually are what are your settings for the following 2 items:
1) Automatically login when you return to the site? (uses cookies)
2) Browse board with cookies?
If you're using the cookie option (recommended) make sure no program is blocking the cookies. If that isn't the issue, then you may need to clear the TGO cookie and revisit the forums, login, to receive a new cookie. Sometimes the cookie becomes corrupt.
Old Jul 26, 2005 | 02:28 PM
Camaroz29's Avatar
Also, everytime you delete all of your temporary internet files it will clear all of your cookies. So if you are a computer "neat freak" like me you will delete them constantly.
Old Jul 26, 2005 | 08:38 PM
JT's Avatar
JT
Yes, if you specifically set out to delete the cookie, you will have to login back in. You should (normally) receive a new cookie at that point.
However, in this case, it seems either the cookie/index is corrupt, or he may not be browsing the forum with the cookie option.
Old Jul 28, 2005 | 10:34 PM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
On IE delete files and delete cookies are a seperate button.
Old Jul 28, 2005 | 11:54 PM
JT's Avatar
JT
There is a seperate button for those settings in the Control Panel, but also, if you're using Windows XP, look in the folder:
C:\Documents and Settings\Your Windows Username Here\Local Settings\Temporary Internet Files
Clear the contents of that directory, close your IE window, and you'll lose your cookie.
Cornholio7979
Sep 20, 2018 02:31 AM
L98GTA87
Oct 19, 2015 10:43 PM
89fast5oh
Sep 27, 2015 09:04 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
