Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Quick post sig default
Old Apr 2, 2006 | 01:26 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Not sure if I'm blind or not, I've looked, but is there a way in the Quick Reply to have the show signature un-checked by default? Unchecking that everytime gets kind of old.
Old Apr 2, 2006 | 03:05 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah there's an option somewhere. I disabled mine, then I set it to go to advanced automatically, not a huge fan of quick reply.
Old Dec 11, 2007 | 09:58 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Re: Quick post sig default
old post but I'm having a similar issue. on the quick reply "show your signature" is checked until I hit "reply" then the check goes away... what gives? Id like it to be checked by default, but don't know how.
Old Dec 11, 2007 | 10:01 PM
JT's Avatar
JT
Community Administrator
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show.
However, if you reply to a thread, if you want your signature to display, you will have to manually place check in the box for "Show your Signature", which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years now, actually.
pwdbychevy
Apr 16, 2023 07:27 AM
Chuck84TA
Jul 15, 2016 09:05 PM
formula_novice
Sep 5, 2015 03:58 AM
