Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
no sig??
Old Jun 8, 2006 | 11:26 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
no sig??
When I go in to change it it's there, but it is not showing when I post?
Chris
humm...it worked there?
Old Jun 8, 2006 | 11:30 PM
JT's Avatar
JT
Community Administrator
If you have a signature, by default, the 'Show your signature' option under the 'Additional Options' section (below the area you type in your message in), will have a check mark by default when you are creating a new thread, such as you done here. Notice your signature appears normal in your post.
However, if you are replying to a thread, that option, by default, will be disabled. If you want your signature to appear when you reply to a thread (not starting a new thread), you will have to manually check the option 'Show your signature' under the 'Additional Options' section each time.
This was something that Dirk done to the old vB forum to help minimize people posting their signature multiple times in the same thread, wasting space. When we upgraded to this newer vB version, I added the same feature.
Old Jun 10, 2006 | 08:25 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks man! I appreciate it!
Old Jul 13, 2006 | 05:46 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I had the same ? ... Thanks!
pwdbychevy
Apr 16, 2023 07:27 AM
formula_novice
Sep 5, 2015 03:58 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Roshambo
Sep 26, 2001 02:45 AM
