Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Script error after auto-merged double post.
Old Aug 1, 2006 | 05:39 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Not quite sure I like the new auto-merge double post, but reguardless..
I replied to a thread and then quoted another post and replied again. After I sent the second post I got this error message on a plain white screen:
Unable to add cookies, header already sent.
File: /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code
Line: 6
I went back to the message create page and decided to check the thread to see if it went through. All I could get was the same white screen message. I went back to the main forum and everything looked fine but this was at the very top of every page:
Parse error: syntax error, unexpected '[' in /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code on line 6
Any message I tried to click on gave me the same white screen error #1. I closed that IE window, and opened a new one. Went back to the main page and at first got this on a white screen:
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/session.inc on line 10
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/session.inc on line 10
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/bootstrap.inc on line 488
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/bootstrap.inc on line 489
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/bootstrap.inc on line 490
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/bootstrap.inc on line 491
Warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/bootstrap.inc on line 492
warning: Cannot modify header information - headers already sent by (output started at /home/httpd/vhosts/thirdgen.org/httpdocs/techboard/global.php(334) : eval()'d code:6) in /home/httpd/vhosts/thirdgen.org/httpdocs/includes/common.inc on line 99.
After a few seconds the main page popped up, with the above erros mixed in with it.
It took closing all IE windows for things to return to normal. Me thinks there's a bug in the auto-merge doublepost that's corrupting a cookie or something.
Kevin D.
Old Aug 1, 2006 | 05:44 PM
JT's Avatar
JT
Community Administrator
It had nothing to do with the auto-merge doublepost feature. It is due to Dave working on the forums. There was a short period of time where accessing/viewing posts resulted in the same error, so it has nothing to do with the auto-merge doublepost feature.
Kevin D.
Old Aug 1, 2006 | 05:47 PM
shr00m's Avatar
Thanks, crazy coincidence as that was the first auto-merge I've had.
Kevin D.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3rd gen money
Oct 11, 2019 09:57 PM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
