Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Photo's linked through cardomain
Old Aug 17, 2006 | 03:51 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
All my pictures linked through cardomain are not showing up. Anyone have a clue?
Old Aug 17, 2006 | 04:18 PM
JT's Avatar
JT
Community Administrator
Looking at your post you created yesterday with 6 hotlinked images to Cardomain, the coding you used on TGO to hotlink the images were correct. The images appear to load directly.
I have to wonder if this is another cardomain hotlinking issue. I've seen things like this occur many times (even on other forums) where members' images on cardomain randomly work/didn't work when hotlinked.
Old Aug 17, 2006 | 05:42 PM
ssean92's Avatar
Car: sold
i had the same issue, the cardomain site went through a update and it changed some of the codes i quess. i just re copied and pasted the link and works fine.
Old Aug 17, 2006 | 08:06 PM
pondriver's Avatar
Engine: 350 HSR
Well, I've deleted them and reposted. It appears I can't link more than one photo.
Old Aug 17, 2006 | 08:20 PM
JT's Avatar
JT
I'm only guessing that it may be a new limitation on cardomain's service through hotlinking, I'm sure there's a lot of bandwidth consumption. In the past, I've seen intermittent issues with people's images hosted on cardomain.
Thanks for your report. I had actually came across a member's post yesterday that had no loading images, which were all hosted off of cardomain.
By the way, I just tested by hotlinking a few of your images on a test page on my own server and the images failed to load as well.
Old Aug 17, 2006 | 08:25 PM
pondriver's Avatar
Engine: 350 HSR
Well, I take that back. I posted one photo and it worked, now I look at it and I'm getting the big red x. I'm going to try another host I guess.
Old Aug 17, 2006 | 08:27 PM
JT's Avatar
JT
You probably seen it the 2nd time because the image was then in your browser's cache. I edited my post above, but as mentioned, I created a test HTML page to hotlink a few of your cardomain images on my own server (outside of TGO) and none of them would load there either.
3rd gen money
Oct 11, 2019 09:57 PM
LC2 TECH
Oct 13, 2015 11:53 PM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
