Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
search option
Old Jun 28, 2007 | 05:27 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
search option
Can we not use the search option?
Is anyone else having this problem?
thx
jeff
Old Jun 28, 2007 | 05:34 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
Re: search option
What type of problem are you having?
I just tried a general search and used the keyword: camaro and it came back and said that no matches could be found. Now I know that is way off lol.
Mike
Old Jun 28, 2007 | 05:58 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: search option
Yup, the search feature is not working. I've tried GTA, LT1, LS1 and it did not find any matches ِ
Old Jun 28, 2007 | 09:09 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
Re: search option
i've also had problems with the search function, site also seems slow to me.
Old Jun 29, 2007 | 10:20 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Re: search option
Yeah, I've been using very common keywords and it's broken.
Old Jun 29, 2007 | 12:39 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Re: search option
Standard!
Old Jun 29, 2007 | 08:35 PM
firstfirebird's Avatar
Re: search option
Broken...
I have to keep answering the same questions over and over that I know have been covered. Since the "down for maintanance" this has been going on. It took me quite some time for me to even find my origional post on the subject just to give them a link.
Old Jun 29, 2007 | 08:51 PM
JT's Avatar
JT
Community Administrator
Re: search option
I posted a brief announcement about the issue, but yes, unfortunately, search is down and will be down until next week. Thirdgen.org had used a "3rd party" search engine, rather than vB's search engine. The new server needs a software upgrade in order for the search feature to work. This will result in some downtime as the software is upgraded. At this time, we cannot turn back to vB's search engine for a few reasons, while leaving the forums online. So, instead, it is planned to have the search feature back online sometime next week when mysql can be upgraded.
Old Jul 1, 2007 | 01:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: search option
some ppl are still posting outside of the site boards here about the search feature not working for them
obviously they arent seeing this post or any announcement
just FYI
Old Jul 1, 2007 | 09:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: search option
I just read a post on C&C t-tops. The peson posting said they tried to SEARCH and found no results. Since I've posted on several threads on these t-tops, I thought that can't be so. I tried searching and came up with nothing. Then I tried searching on my username and still nada. Then I tried other terms I've posted on, (hatch motor, headlight motor, etc.) still nothing. Yep, I'd say the SEARCH function is broken. So before anyone jumps on antother TGO Member that they need to search, try it yourself. You may be surprised as I was by the results of your efforts.
Lon
Old Jul 1, 2007 | 09:20 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: search option
Yup i had noticed this lately and they i said F it let me search CAMARO and nothing came up so then i said there has to be a problem sure enough just found this thread...kind of a pain cause i really dont want to make new threads for stuff i think has been covered but oh well.
Old Jul 2, 2007 | 02:26 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Re: search option
Now I can't use this. lol. But ya. I can't what for it to work. It seems like when it's down. I need it the most. But I know you guys will get it going again! Adam :-)
Old Jul 3, 2007 | 12:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: search option
Rather then posting bullitens about which obviously most people dont read. How about making it so when you select the search feature, it says "not currently useable due to working on site upgrades". That way, people know its not broke, but currently disabled.
How about also knocking it down from 45sec, to 30 or 20?
Old Jul 3, 2007 | 01:59 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Re: search option
Dale has a good point about having a message on the search result that says currently disabled, etc.
not going to be able to avoid ppl posting common questions until search is workign again
i have noticed a huge increase in computer/est system removal questions and engine v-6 to v-8 bellhousing pattern questions too
among other basic commonly asked stuff as well
i try to post to those questions because i can put up with repetitive/repeat info replying
you keep wanting ot refer ppl to certain thread(s) to help them with their common question post but then you remember that search is not working and so you cant find said threads to refer them to
lol
search feature- just like electricity, water, food and so on- is taken for granted, and then when its broken its no fun lol
amusing in a crazy way,
so for now theres going to be alot of repeat posting and very basic questions posted that normally would not be
as much anyways
Old Jul 3, 2007 | 04:31 PM
JT's Avatar
JT
Re: search option
Actually Dale, I had done exactly just that. In fact some likely had seen it when I briefly had the search box replaced with such a notice. However, for a few reasons, I reverted it back to normal and left the announcement.
In regard to the search timeout limit, that's been a fairly common suggestion. However, I do not believe members understand that it's not simply just a number set to inconvenience members who search. Instead, the search timeout can play a large role on the server's performance, thus impacting everyone.
Generally, it's better to impact a group (those using the search at that given time), rather than impact the entire members with slow page responses due to the server being busy serving those search requests.
We're not trying to discourage searches, and some may argue that is exactly what we're doing indirectly. However, those may not understand running a website the size of TGO, with it's fairly large database and user activity, does not run on cheap hardware. That's not even to mention that stock vB search engine isn't exactly without it's own problems.
Perhaps down the road the search timeout can be tweaked lower if the server can handle it efficiently.
Old Jul 3, 2007 | 08:51 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Re: search option
You guys should use the google search, works way better.
Old Jul 4, 2007 | 12:33 AM
Re: search option
That's what I have been using lately. I don't think it's as good as the regular one. But it gets the job done. Adam :-)
Old Jul 4, 2007 | 12:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: search option
Originally Posted by Randy82WS7
not going to be able to avoid ppl posting common questions until search is working again
I hope that is not the case, as I have noticed a huge dropoff in the number of posts lately. I usually am able to check the board once a day, and I click on "New Posts." I used to see 450-550 a day, but now I am seeing only 250-300 a day.
Old Jul 6, 2007 | 01:31 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Re: search option
Ashame this place has been such a cluster**ck since the new owners came on board. Its dieing a slow painful death.
Old Jul 9, 2007 | 08:11 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: search option
The ThirdGen search seems to be working again - Sort of. I have to admit; It's nice to be able to search thru each individual forum again ! - BUT - It looks like we lost almost 6 years of data ! Thers a gap from 12-01 till 7-07 when using the "Show Thread" option !
When using the "Show Post" option there is no new posts at all.
Please tell me that the last back-up of the Third Gen tech boards wasn't back in 2001. I have noticed that the Google search isn't locating any recent posts at all.
Will the ThirdGen search feature ever return any of the post from 12-31-01 till 07-04-07 again ???
Old Jul 11, 2007 | 09:15 PM
John in RI's Avatar
Re: search option
Search seems to be working again < knid of working anyway > !!!!
Nice work guys !!!!!
seiplentz
Aug 19, 2019 06:02 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
