Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Why isn't my sig showing up?
Old Dec 29, 2007 | 10:33 AM
turbodave's Avatar
Car: 84 Z28, L69
Engine: 5.0 HO
AS the title says, why isn't my sig showing up on my posts?
It shows up here, but not in another thread I posted in.
Like in this thread: https://www.thirdgen.org/forums/sout...esseeians.html
Old Dec 29, 2007 | 10:41 AM
JT's Avatar
JT
Community Administrator
Re: Why isn't my sig showing up?
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show - as it did here.
However, if you reply to a thread, if you want your signature to display, you will have to manually place check in the box for "Show your Signature", which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years now, actually.
PestilenceIV
Sep 11, 2016 12:53 AM
69GTOby
Apr 18, 2016 02:34 PM
Racerx974
Sep 19, 2015 10:16 AM
ronchic
Mid-Atlantic Region
Sep 10, 2015 02:32 AM
Glowsock
Sep 6, 2015 06:40 AM
