Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Cant post new threads or post replies
Old Feb 6, 2008 | 06:35 PM
Anthonys434's Avatar
Car: 83 Z28 Camaro
Engine: 5.3L L33
Transmission: 4L65E
Axle/Gears: GM 12 bolt 3.73
I have not been able to post new threads or replies for the last two or three days now. I have only been able to post here and in the classifieds not in the regular disscusion boards. What is wrong and how can i fix this?
Thanks much
Any help would be apreciated
Old Feb 6, 2008 | 06:37 PM
AmorgetRS's Avatar
Re: Cant post new threads or post replies
Are you trying to post in the classifieds?
Old Feb 6, 2008 | 06:43 PM
JT's Avatar
JT
Community Administrator
You will need to provide more details. Errors? What happens or doesn't happen?
I checked your account and it's OK. You can post in the Classifieds (which you did state you could), and should be able to post everywhere. You are in the same usergroup as thousands of other members that have been posting in the forums. There is no different permissions between the forums, other than the Classifieds.
So as it sits, I need more information as your account is normal.
Old Feb 6, 2008 | 06:51 PM
Car: 83 Z28 Camaro
Engine: 5.3L L33
Transmission: 4L65E
You are not logged in or you do not have permission to access this page. This could be due to one of several reasons:
  1. [*]
Log inUser Name:
Password:
Forgotten Your Password? Remember Me?
The administrator may have required you to register before you can view
This is what i get every time i try to post a new thread
Old Feb 6, 2008 | 06:55 PM
JT's Avatar
JT
Clear your TGO cookie that your browser uses. How you do so depends on the browser you're using. You can simply delete all cookies, but then you will lose automatic login and cookie-based preferences for other websites.
After doing the above, revisit the website and login (I suggest you pick the remember me option).
Old Feb 6, 2008 | 07:06 PM
Car: 83 Z28 Camaro
Engine: 5.3L L33
Transmission: 4L65E
I did what you said but it still did the same thing to me. Any othe suggestions?
Old Feb 6, 2008 | 07:11 PM
JT's Avatar
JT
The information your provided shows that you are not staying logged in - which is a cookie issue. Cookie issues are almost always user's end, especially if others are working (and that appears to be the case).
If the above did not work and you are sure you really deleted the TGO cookie, then you probably have some type of security software blocking the cookie or have some custom setup.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Chuck84TA
Jul 15, 2016 09:05 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Linson
Aug 21, 2015 02:12 PM
