Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Sig
Old Feb 8, 2008 | 09:53 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Sig
Why doesn't my sig appear every post I make? It only seems to appear if I start a thread. For some people it appears every time they post. Thanks.
-Greg
Old Feb 8, 2008 | 10:43 AM
JT's Avatar
JT
Community Administrator
Re: Sig
-Greg
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show - as it did here.
However, if you reply to a thread, if you want your signature to display, you will have to manually place check in the box for "Show your Signature", which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years now, actually.
Old Feb 8, 2008 | 05:21 PM
Engine: 400
Re: Sig
Thanks much. I see it.
Old Feb 9, 2008 | 12:43 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Re: Sig
One sig per thread is enough anyway, really.
pwdbychevy
Apr 16, 2023 07:27 AM
formula_novice
Sep 5, 2015 03:58 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Roshambo
Sep 26, 2001 02:45 AM
