Signature problem
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Signature problem
Never mind, by making a new thread it now shows up. Sorry.
Re: Signature problem
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show - as it did here.
However, if you reply to a thread, and if you want your signature to display, you will have to manually place check in the box for "Show your Signature" each time, which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years.
