Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Pic problem
Old Sep 20, 2009 | 09:56 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Pic problem
Can not upload pictures off my drive more than one time to a thread.
Get the responce that is already uploaded before to a different thread.
Have tried renaming pic but same result.
My end or suggestions.
Later
Old Sep 20, 2009 | 10:11 PM
JT's Avatar
JT
Community Administrator
Re: Pic problem
That is the way the system has been setup for the past several years in order to help control the size of the attachments on a forum this large (which is measured in GBs). There has to be some limitations placed to help keep things in order, for lacking details. A user probably wouldn't have the same file stored multiple times on their own computer's hard drive.
Unfortunately, until vB 4.0 is released, the stock vB software does not handle this particular situation in the most user friendly way. However, because the image is hosted on the server, you can link to the image and post the image inside the post - which is not difficult to do since the system does give you the location as to where the image was used.
Later
Infested
May 22, 2018 11:56 PM
aaron7
Aug 17, 2016 06:02 PM
db057
Sep 4, 2015 07:57 AM
dyeager535
Aug 28, 2015 08:10 AM
neekolzun
Aug 24, 2015 04:59 PM
