Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Why is my sig not working?
Old Jul 26, 2010 | 10:50 PM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
Tried a couple different ways but its still not working . Any suggestions?
Old Jul 26, 2010 | 11:12 PM
JT's Avatar
JT
Community Administrator
Re: Why is my sig not working?
Signature appeared in your post here.
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show. This is why it appeared in your example above.
However, if you reply to an existing thread, and if you want your signature to display, you will have to manually place check in the box for "Show your Signature" each time, which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years.
Old Jul 26, 2010 | 11:16 PM
Roc THIS's Avatar
Engine: 5.7 TPI
Ah I see . Ok . Out of all the forums I am on this is the only one that has given me problems . Thanks for the help JT
Old Aug 24, 2012 | 06:43 PM
A&TZ28's Avatar
Car: 1987 IROC Z28
Engine: LB9
Axle/Gears: 9 Bolt w/3.27's
How do i activate the signature option and what and where is "userCP"?
Old Aug 24, 2012 | 07:24 PM
JT's Avatar
JT
The UserCP is located on the navbar up top and is where you edit your signature and other account-based details and options.
As the posts state, by default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked. That option is below where you type your message. Your signature will then show.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
