Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Digging up old posts...
Old Jan 30, 2015 | 12:46 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Is there any way to dig up a group buy thread from back in 2009? It was for the then new Tick Master Cylinders. Would have been around 1/30/2009...
Im trying to confirm that they supplied a remote bleeder line with those group buy orders or not. I tried searching under my name, but my posts only go back to 2010.
Anyway to access that stuff?
Justin
Old Jan 30, 2015 | 04:29 PM
JT's Avatar
JT
Community Administrator
Re: Digging up old posts...
All the content is searchable and available. Since the results are limited, you will need to provide more specifics to narrow the results to fit within the limited returned results.
So it sounds like you need to use the advanced search, use your username, select the Group Buy forum (if that's where it was at) and may even change the date range to search older threads.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Hawk312
Aug 22, 2017 08:55 PM
InfinityShade
Feb 21, 2016 01:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
