T56 Swap and new starter?
Old Mar 7, 2010 | 07:42 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hello all,
I've just about finished my T56 swap, but I ran into an impass today. I'm hooking a T56 up to my factory LG4 305. I used a NAPA flywheel for a 93 Camaro Z28 (same car the trans came out of). I got ready to bolt it all up today, and to my surprise, the starter wouldn't fit?
I've read about every swap I could find, and I've gone over all the lists, and I just haven't seen where anybody had to swap to an LT1 starter, at least not on a one piece RMS block?
The problem is, the rounded aluminum part on the end of the starter that used to go through the plastic inspection cover on the TH700 will not fit inside the bellhousing on the T56. The casing that covers the starter gear is simply too large to go in the hole in the bellhousing. Do I really have to get a new starter? If so, what starter works? An LT1 starter?
Thanks for the help guys. I need to get this thing ordered tonight or tomorrow so I can have it in by Friday.
Here's the rest of my swap, just in case you'd like to see the rest:
https://www.thirdgen.org/forums/memb...engineers.html
-Levi
Old Mar 7, 2010 | 08:27 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
Re: T56 Swap and new starter?
you either need the lt1 starter or just a starter for a 3rd gen with a manual, the nose on the starter is considerably smaller for manual trans. i had the issue when i went 700 to t5
didnt know it was an issue with the t56 also, but now i do
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Any LT1 starter will work, the gear reduction LT4 starter is a little nicer but more $. The stock T5 starter would have worked, but automatics came with a large starter that won't fit and a smaller one that does.
Old Mar 7, 2010 | 09:46 PM
Engine: L98/454/M20
So, there are two different starters that could be on an automatic? I parted out my '87 305 TPI Trans Am with a TH700. Any chance that would have had the smaller nose starter that will fit?
Thanks,
-Levi
Old Mar 9, 2010 | 12:51 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Thanks,
-Levi
Sure, it's possible. Parts get swapped out over the years.
Here's the bigger one (3" across) and the smaller one. The smaller one works better than the big one with T5 bellhousings and it works with the LT1 T56 bellhousing.
Enjoy your swap.
Attached Thumbnails T56 Swap and new starter?-p1010066.jpg   T56 Swap and new starter?-p1010067.jpg
Old Mar 9, 2010 | 11:28 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Check this one out on my parts overview:
https://www.thirdgen.org/forums/tran...-overview.html
It's worked really well for me and is significantly smaller than stock allowing for better heat isolation and header clearance. You do have to grind a little on the block side of the starter though. Just a little and it bolts right on. No third terminal either.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
