T5 reinstall under the car?
Car: 1985 Pontiac Trans Am
Ive read some post on removing engine and tranny.I was planing on pulling the tranny under the car and the motor from the top.How hard is it to get the t5 back in place under the car???
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T5 reinstall under the car?
Car: `86 SS / `87 SS
it's easier than a t56
I don't know if you'll have the clutch off, but before you put the engine back in, make sure the clutch is lined up so that the input shaft slides right in and the trans. bolts up to the bellhousing. That's about the only potential hard part about a T5.
Car: 87 GTA
I don't know anything about the "extra hand" part. I've always done them solo.
If you get the clutch lined up good (don't bother even trying without the alignment tool) then it usually goes in pretty easy. Worst part is reaching the upper tranny to engine mounting bolts.
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
dude just do it this way.
I've done it by taking the trans out from under and engine from the top and yea it will all go back in without to much trouble that way.
but i found just dropping the engine and trans together from the bottom is way easier
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
That's f-ing nuts. I do that all the time on a 4th gens. I am going to have to respectfully disagree and say that it not easier than pulling it out from the top.
well for whatever reason i found it alot easier than pulling it out from the top...but thats just me anyway i guess
Thanks guys.I pulled the tranny out the bottom.piece of cake!I decided when I drop in the new motor in to just install the clutch assembley and bell housing then bolt the tranny from under the car.Thanks for all the input.BTW This tranny can be pulled in about 30 minutes ounce the car is jacked up and when u pull the tranny fist(4 bolts)Then the bell housing bolts are easily accessible.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Man I hate doing this alone! If it slips, you're ****ed. I did my T56 install alone with a 2X4 strapped to it. T5 would be easier and you've discovered.
Linson
Aug 21, 2015 02:12 PM
