Paint and Body Project on my 89 IROC
Old May 21, 2016 | 09:44 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Paint and Body Project on my 89 IROC **Finally Finished**
So it's time I finally get the old girl ready for paint. I will be prepping the car, stripping her down, sanding her, and taking her in for a MAACO paint single stage Urethane paint job in the original White. I started today by removing the stripes with a 3M Eraser wheel and then removing the front bumper cover so I can fix the giant crack between the fog light opening and the turn signal on the driver's side. I will be using Eastwood epoxy primer (I hear its just Kirker Enduro Prime) and Finish 1 FP410 2K primer for the spot repairs I will have to do. This is going to be a summer project so I plan to update it as I go (mainly every weekend).
Before.
Before.
Before.
Before.
Stripes Removed.
Stripes Removed.
Old May 21, 2016 | 09:48 PM
Matt trans am's Avatar
Car: 1985 trans am
Re: Paint and Body Project on my 89 IROC
Nice
Old May 21, 2016 | 09:50 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
What's left of her stripes.
3M Eraser works like magic.
Cracked/torn bumper cover.
Grill insert and turn lights removed.
Front Bumper cover removed.
Old May 22, 2016 | 10:06 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I would replace that bumper cover and mirror. IMO
Old May 23, 2016 | 06:08 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
For the cost of a bumper repair kit I am going to make a attempt at repairing the bumper cover myself. If it fails or I bugger it up completely I am more than ready to buy a new one. As for the mirror, if you look closely you will see a dent under the mirror. The guy bought it off of said that a shelf in his garage collapsed and something heavy landed on the mirror. It not only dented the mirror but it peeled the top of the door skin about 2 inches away from the glass. I was able to straighten it out so its not noticeable but the whole door needs replaced as I intend to do. So yes I will replace the mirror with the door and I will replace the bumper cover if my repair looks bad. I appreciate the opinions.
Old May 23, 2016 | 11:26 PM
Agreed 100%. I just finished lots of bumper work on mine, filling in the big factory indentations and repairing a 3-4" crack in the middle of the bumper. It was a time consuming project. Your crack is very long and goes to an edge. You would need to use strips of urethane and epoxy them over the cut like you would steri strips on a deep cut on your body. You would also want to drill through the bumper and urethane strips so the epoxy had little finger projections to help hold it. Seriously for the amount of time and supplies you'll have in this you're better off grabbing a better piece from a yard or part out. I would also heavily advise against single stage. It will never have the gloss or depth of a base coat clear coat. You also won't have the level of uv and scratch resistance a clear coat has. Difference in price for single stage vs clear coat isn't really night and day either. You'll want this paint job to last the entire time you own the car, don't end up wanting to kick yourself everyday when you think you only did this to save a few bucks.
Seriously, you'll have more than you think in repairing it. You'll need the flexible bumper adhesive, flexible filler like poly flex, compatible plastic strips. If you found a bumper for $100 take it. After $100 it just depends on how much time you have vs funds.
Old May 25, 2016 | 11:03 PM
Brando5641's Avatar
My 89 I painted had a badly ripped front bumper. I was able to repair it but like Tibo said, the amount of time alone is worth jut finding another bumper. I understand if you are on a super tight budget but if you can afford it get another bumper.
If you have no choice but to repair it use the 3M or Bondo brand Bumper repair 2 part epoxy. It works good.
If you are looking for a budget friendly paint go to Paintforcars.com Get basecoat clear coat. Its much more forgiving.
Not trying to nit pick just speaking from experience.
Old May 29, 2016 | 01:14 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Back side of the front bumper cover before trimming the extra fiberglass tape.
Front side curing.
Old May 29, 2016 | 01:16 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Pulled off the body molding strips, the IROC badges on the rocker ground effects, the outer door sweeps, and the side mirrors.
Old May 29, 2016 | 01:19 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Badge removed.
Molding and outer door felt removed.
Old May 29, 2016 | 01:21 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
I dont think i have the talent to fix this, so im gonna replace the door.
Old May 29, 2016 | 01:46 PM
I would remove the door and take it to a body shop or welder then. It wouldn't be difficult to cut that out and weld in a new patch. Same process as shaved door handles. Compare that price to a parts yard door in good shape. A different door will probably be a different color which would mean sanding the entire thing down and it would possibly hang differently.
Old May 29, 2016 | 02:04 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
That's an idea I hadn't thought about. My local junkyard has an 86 Z28 door for $150. It's blue with PW, PM, and PL's. They also have a white door from a 91 Firebird but then I would have to drill the door for the gfx.
Old May 29, 2016 | 02:39 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
as far as i know the doors for camaro's and firebird's are a different shape.
Old May 29, 2016 | 02:43 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
The doors are the same. It's the GFX that are different
Old May 29, 2016 | 07:16 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Got a couple of low spots but its definitely looking better.
Old May 30, 2016 | 12:56 AM
Billgluckman's Avatar
It'd be a lot cheaper to replace the door in my area. A door is 60 bucks in the junkyard here.
Old May 30, 2016 | 07:46 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Man, I'm jealous.
Old May 30, 2016 | 10:52 AM
dbrochard's Avatar
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
If you want I have a manual mirror and a power mirror for that passenger side you have to replace. PM me if you are interested
Old Jun 4, 2016 | 10:56 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Got some 2k primer on it this morning. Its got a little orangle peel but nothing I cant sand out.
Old Jun 4, 2016 | 10:03 PM
It looks like it came out well. The chin spoiler being bolted to the bumper cover will add some strength but I would still be extremely careful not to flex it when handling it until it is mounted and then be very careful when pulling up to parking blocks, curbs or walls. It looks like you did a good job but I would still be conscientious about the strength of it.
Old Jun 5, 2016 | 08:43 PM
Brando5641's Avatar
^^^^^^ Yes
Old Jun 6, 2016 | 05:11 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
I agree. I will be taking it easy with the bumper cover. I do have to say that so far it seems pretty strong with the back side reinforced with the fiberglass mesh.
Old Jun 8, 2016 | 08:09 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Ok, so i thought i would at least take a shot at the door dent (see above #11 for the before). What do you guys think about my hammering skills so far? The problem is the damn door reinforcement strip that runs behind the top half of the door. I cannot get a dolly on the backside at all. I figured spending a couple of hours on this might be cheaper than a door swap. If anyone has any recommendations I am all ears.
Old Jun 9, 2016 | 10:28 AM
Just be cautious not to overwork the area and get the tin can effect. If you can push it in and it rebounds out or vice versa it really takes a skilled person to fix it.
Old Jun 13, 2016 | 06:33 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Slathered it in some bondo glass to give the mounting holes some strength. Don't worry none of the dents are deeper than an 1/8th of an inch.
Old Jun 13, 2016 | 06:35 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Sanded the fiberglass with some 80 grit. They are not joking when they say this stuff is hard to sand.
Old Jun 13, 2016 | 06:39 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
After getting the fiberglass sanded out I filled the low spots with body filler. Then I sanded it with 80 grit and 180 grit and feathered the paint edges with 180 then 320.
Old Jun 13, 2016 | 06:41 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
3 coats of Eastwood Epoxy primer later. Yes it has a few runs but i will sand them out. I just wanted to get the bare metal covered.
Old Jun 19, 2016 | 09:13 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I would sand the body down with 400 grit or so and use the stock paint as the base without sanding the whole car down to metal. Just bare metal wherever the bad paint checking is and where the bondo needs to be applied. Then finish off with high build primer and last minute block sanding before taking it down to MAACO
Old Jun 20, 2016 | 08:57 AM
If it's a dark or metallic color go to 600 grit. You can use a pre existing paint job as a base before color but the adhesion of the color coat may be effected. Always best to at least spray a coat of epoxy primer of the same manufacturer that made the paint you'll use.
Old Jun 27, 2016 | 08:02 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Been busy at work so this has been a slow project. Finally got the spoiler and tail lights removed. A lot of grime under there.
Old Jun 27, 2016 | 08:16 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
That is pretty much the plan.
Old Jun 27, 2016 | 08:22 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
That is pretty close to the plan. Since I am keeping it White I was planning to only spot prime the areas that need it and have MAACO use a sealer.
Old Jun 27, 2016 | 08:23 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
I am planning to keep it white but pay for MAACO to use a sealer since I will be spot priming.
Old Jul 9, 2016 | 10:24 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
**UPDATE**
I broke my foot in four places on the 3rd of July in an ATV accident so sanding the body for paint has been put on hold. I will continue to update with any progress I make but the doctor said no walking for 6 weeks.
Old Jul 9, 2016 | 10:48 PM
Ouch. Sorry to hear that.
Old Oct 3, 2016 | 06:34 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Update:
So I'm finally up and walking again after crushing and breaking my foot in 14 places. I got all the paint that was flaking off on the A pillar, roof, reardeck, quarter panels sanded off. Then I sprayed it all with Eastwood's Epoxy primer. I managed to get a lot of runs on the quarter panels so I waited 7 days and wet sanded it all with 320. The plan is to spray it with Finish 1 2K high build primer this weekend. Pics are below.
spurgeon76's Avatar
Car: 1989 IROC-Z
Old Oct 3, 2016 | 06:35 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Old Oct 3, 2016 | 06:36 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Old Oct 3, 2016 | 06:37 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Old Oct 5, 2016 | 03:41 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Good work! How's the foot?
Old Oct 7, 2016 | 06:00 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
The foot is slowly getting better. Because I crushed it, it's still swollen.
Old Nov 10, 2016 | 03:30 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Finally got the Urethane primer laid down
Finally got the Urethane Primer laid down.
Old Dec 23, 2016 | 08:44 PM
badazz81z28's Avatar
Spurgeon, where you at on this?
Old Jun 11, 2017 | 04:29 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Update: Block Sanding sucks.
Old Jun 19, 2017 | 12:13 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Update: Block sanding on the back half of the car is finished. I need to spray a few low spots with more urethane primer, then block it again. I will start sanding the old paint this week.
Old Feb 5, 2025 | 03:25 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
It only sat in primer for 8 years before i got back to finishing it. But here is the finished product that i picked up today.
Old Feb 5, 2025 | 03:39 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Looks good! Nice work as well on the prep. And I thought I was the only one who had a third gen in the garage (completely torn apart for paint), sitting in high build primer (for years now).
