DONE - Reproduction Delco Freedom Battery stickers/labels?
Old Jun 21, 2012 | 03:43 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Original Battery decals
Would be nice to have a OEM looking (well as close you can get this days) battery for our cars.
I beleive they all came wiht the black top / white sides Delco Freedom batteries from the factory, see photo attached.
My thinking was to use a flat top battery (just got a new one ordered) and use a reproduction sticker on it ... however not sure if anyone reproduced them already?
Any help much appreciated.
Attached Thumbnails DONE - Reproduction Delco Freedom Battery stickers/labels?-sdc10310.jpg
Old Jun 21, 2012 | 04:22 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Anyone seen reproduction Delco Freedom Battery stickers/labels?
Good question...would be nice to see these labels reproduced, they're a nice touch of originality. Delco batteries are generally junk, but I wouldn't mind dressing up my non-Delco batteries so they at least look correct.
Old Jun 21, 2012 | 04:57 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It's only a matter of time before reproductions and "battery toppers" come out for the Delco Freedom batteries. The Corvette guys will probably be the ones that make it a reality. Reproductions of the old 1970's Delco R59 and R89 batteries have been available for a while now.
Occasionally I'll find a car at an old junkyard that still has a Delco Freedom battery in it. I thought about cutting the top off with a hacksaw and making my own "battery topper."
Old Jun 21, 2012 | 05:03 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I contacted Peter Klutt from Legendary Motorcars in Canada a few years back and asked if he had any interest in reproducing these. He has the license or patent or whatever it is to manufacture battery toppers in the US. The 60s muscle cars that have a factory looking battery topper came from Peter's inventory. He said that there isn't much demand for Delco battery replicas because there aren't enough people trying to restore the 80s GM cars. Unfortunately, he did say that there does seem to be more interest in the late 70s and early 80s Mustang market, that they will probably reproduce those first.
This is, again, a slap in the face of third gen owners because of our own lack of restoring these cars and how cheap many of us are.
Old Jun 21, 2012 | 08:33 PM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
My first thought would be to call Jim Osborn Reproductions. He has a lot of decals for older stuff. I used him a bunch in the restorations of my 79 and 80 Z28 and the 75 Formula that I did. he is great to deal with and listens to us hobbyist. Their was some strong interest in the early delco batteries a while back but I did'nt worry about it after I just peeled off the labels of the battery I had and cleaned it up. It just disappeared from the engine compartment cause there was nothing drawing attention to it. Hopefully someone will come up with something. Another place to call would be Coker Tire. I know they are into everything.
http://www.osborn-reproduction.com/
Old Jun 22, 2012 | 01:33 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
I tried Jim Osborn for some other stuff however with the slow business these days he said he's not investing in new projects :-(
All we need really is a really good scan of an original sticker along with the dimensions and I can most likely get it done ...
Old Jun 25, 2012 | 04:15 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
anyone
Old Jun 26, 2012 | 10:40 AM
Slater126's Avatar
Sad but definitely true. I've found myself stunned at key parts that are no longer available that I had to score used from Henry D -- Fuel tank vent valve (no biggie, it just makes the car smell like it's leaking gas!), HVAC control valve (causes a vacuum leak and your ducts to not work), and the EGR solenoid (will cause your EGR to not work and you to fail emissions). I'd hardly expect an OEM battery to be available yet. I'll settle for the items that will make the car not blow up and run properly! Hopefully this changes over time.
Old Jul 11, 2012 | 02:54 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Perfect for a flattop battery like the ones you can buy @ Napa, Sears (I think) etc ... I pulled the stickers on the one I bought (same manufacturer as the Napa and Sears ones) and looks great.
Attached Thumbnails DONE - Reproduction Delco Freedom Battery stickers/labels?-installed-1-.jpg
Old Jul 11, 2012 | 12:56 PM
navy02ws6's Avatar
Re: DONE - Reproduction Delco Freedom Battery stickers/labels?
WOW, those came out great! Nice work!
Old Jul 11, 2012 | 01:12 PM
puma1552's Avatar
Those are excellent, very nice! I don't know if the battery I just put in my car is a flat top or not, it's a Delco but I'd have to check. Most likely though you'll be out of them by the time I get out to the car to look at it.
Old Jul 11, 2012 | 01:48 PM
82tarecaro's Avatar
The question is - what is the best battery to put that on that is closest to the original?
Old Jul 11, 2012 | 04:06 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
This is what I got ... they are US made and they manufacture them under different labels.
http://www.dekabatteries.com/default.aspx?pageid=454
Napa, Sears etc.
The original batteries had black tops and white body and I never seen one like that since the 90's so the above is second best ... but they do not have the "eye" like the Delco's have however the Delco's these days are not flat tops like they used to be ...
Old Jul 11, 2012 | 04:26 PM
BADNBLK's Avatar
PM sent!
Old Jul 11, 2012 | 04:33 PM
scottmoyer's Avatar
There's not going to be a demand until people know what their cars came with. The battery you posted and the sticker you had created based on that battery are incorrect for the 1987 model. There were many different looks to the Delco Freedom batteries during the 82-92 run.
Because of this, I contacted Remy today and spoke with one of their marketing reps to see if they can provide images of each year's battery. I'm waiting on their response, but they mentioned that they haven't been in that industry for about 15 years, so they would need to look into the archives.
Here are the images I have from an 81, 85 and 87
Attached Thumbnails DONE - Reproduction Delco Freedom Battery stickers/labels?-81battery.jpg   DONE - Reproduction Delco Freedom Battery stickers/labels?-87-delco-battery.jpg   DONE - Reproduction Delco Freedom Battery stickers/labels?-85irocbattery2.jpg
Old Jul 12, 2012 | 02:08 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
I'm fully aware of that and the same sticker have different details with regards to CCA, lifespan etc as well depending on car model they ended up in ... as well as the over the counter replacements from the same year could be slightly different as well ... oh and some that the factory used came from the Canada plant so again a slightly different decal.
Old Jul 17, 2015 | 06:15 AM
25yearGMtech's Avatar
the Red/White/Blue battery is one they need to repo.
They were used from late '73 to 82ish?
the Corvette guys don't want them because the Vettes of those years were kind of blah.
except for the '78 25th anniversary, they really don't care about their battery.
Camaro folks are different.
if I had a 1976 Camaro, I'd really want that patriotic theme underneath the hood.
Old Jul 17, 2015 | 09:52 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Red-White Sticker on the Blue Battery (81), looks almost identical to the Black with the White & Yellow stickers (85) the only difference is the colors and the decals. I wonder if they just changed suppliers.
Old Jul 17, 2015 | 11:01 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
With the way tech is going I can see car batteries becoming so small that you could find an original delco freedom, gut it, and use it as a shell for your entire new battery, while maintaining the look of a fully wired and stock factory battery.
Old Jul 12, 2016 | 04:21 PM
secondgenta's Avatar
Hope you don't mind me bringing up an old topic to answer that.
The Freedom Battery came out in 1975 during the excitement about the nation's bi-centential 1776-1976, so many things were Red, White & Blue, including some Special Edition cars, like Chevrolets "Spirit of America" edition cars. I think Buick had something too iirc.
By 1982-3 the patriotic displays had faded and it was during the design process of the c4 Corvette, Chevrolet/GM requested that Delco-Remy the Mfg change the colors, because the battery location was being moved from in cabin compartment in c3 (unseen) to underhood a on the C4 Corvette and very visible, right at the clamshell hood opening, Chevrolet wanted the battery to compliment the Silver and black engine, not to stand out. The Battery should be and i think is Black with Silver that just looks white in the pic.
Basically the same battery just different color tops and labels.
Old Jul 13, 2016 | 09:54 AM
Aside from the $25 reproductions on ebay, has anyone seen any sources for Delco battery decals lately?
Also wondering if anyone has come up with any kind of definitive guide to which labels were used on which cars. For all the low mileage cars out there, it's surprising how difficult it is to find clear pictures of this kind of thing.
Old Jul 13, 2016 | 10:03 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I still have my original battery for my '89. It's in the attic. If anyone needs them, I can go up there and take some pics.
Old Jul 13, 2016 | 10:08 AM
The battery pic in Jans 1st post was from a 92 GTA I parted yrs ago.
I also sent him a scan of the original battery from my 89 formula 350.
He redid both of those decals.
Old Jul 13, 2016 | 10:10 AM
chazman's Avatar
Axle/Gears: BW 3.45
BTW, my original battery lasted 11 years. Nope, they don't make 'em like they used to.
Old Jul 13, 2016 | 11:14 AM
GASPEDDLER's Avatar
Charlie, I would like to see some pics if it's not too much trouble.
Old Jul 13, 2016 | 12:13 PM
A 89 formula 350 battery. I put plastic on the top when I scanned it.
Old Jul 13, 2016 | 12:18 PM
GASPEDDLER's Avatar
Thanks!
Old Jul 13, 2016 | 01:11 PM
92GTA's Avatar
Good to know, I just saved that pic for the future
I had a battery case that fit around an Optima for my '56 Corvette that was perfect match for the original. We need those.
Old Jul 13, 2016 | 04:23 PM
Here is the modified original 92 battery in my 89 formula. Handy place to install the MSD ;-)
Factory battery cables are hooked up and the car can be jumped from there as well.
Old Jul 13, 2016 | 04:42 PM
92GTA's Avatar
That is a slick!
Old Jul 13, 2016 | 09:27 PM
Stuart S's Avatar
You know, some members here have C3 Corvettes, too, and "blah" is apparently your opinion. I personally have an '81. Much of the reason there is limited interest (although there is still interest) is because the battery on those cars is in the rear of the interior compartment, behind the driver's seat, in a closed compartment; not in the engine bay.
Old Jul 14, 2016 | 07:49 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I bought one of those decals, I think,on ebay.
Old Jul 14, 2016 | 09:57 AM
So how about a battery label from 1991? lol
Old Jul 14, 2016 | 10:07 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Here is the 92 battery in my 89 formula. Handy place to install the MSD ;-)
That's slick! Does it get hot in there??
Old Jul 14, 2016 | 12:47 PM
Not really, I remove the lid if I'm driving a lot.
Old Jul 14, 2016 | 05:25 PM
Me too! Just waiting until my current AC Delco battery dies. It has an integral carrying handle built into the top...not decal friendly.
Old Jul 14, 2016 | 05:34 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Well crap... I need 3! I never even gave it a thought till this thread. I'm running AC Delco's now.
Old Jul 14, 2016 | 06:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Here they are on Ebay!wish they had the Green Dot for them
http://www.ebay.com/itm/DELCO-batter...FU4QAP&vxp=mtr
Old Jul 14, 2016 | 06:46 PM
I think that's the guy that bought one from Jan, copied it and is now selling them off his work and my scan.. People suck sometimes
Old Jul 14, 2016 | 06:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
I bought them on 2/14/14 from the same seller as I listed above,is that the guy?
Old Jul 15, 2016 | 08:13 AM
Not 100% sure but he was from NY. The original thread was started here or on the TTA board
Old Jul 15, 2016 | 04:35 PM
skylark3300v6's Avatar
Greetings all,
I just joined this group because I wanted to share some artwork with you.
Your posts inspired me to do my own label for the 1990 Buick that I am restoring, and I thought it only fair to share them with you.
I've added the battery labels, but I also attached some additional labels that were used in the late 80's to early 90's.
I just printed them on vinyl with my laser printer, then carefully cut them out. They look amazing. I've added photos too.
There's a Buick catalyst label in there as well... I doubt anyone here will need that one...
Please enjoy, and thank you for your photos! They made this possible!
Mike
Attached Thumbnails DONE - Reproduction Delco Freedom Battery stickers/labels?-delco-freedom-1990-label.png   DONE - Reproduction Delco Freedom Battery stickers/labels?-buick-labels.png   DONE - Reproduction Delco Freedom Battery stickers/labels?-3300-engine-done.jpg   DONE - Reproduction Delco Freedom Battery stickers/labels?-battery.jpg   DONE - Reproduction Delco Freedom Battery stickers/labels?-delco-battery-buick.jpg
Old Jul 15, 2016 | 05:19 PM
Drew -
The label in my previous post is correct for 1990 and 1991. I'm sure of those years at least.
TTOP350 -
I could never sell this - mainly because it was people like you that provided the photos that made it possible for me to do this. That, and I'm sure that there are some legal issues with selling something that has Delco's old logo on it without permission. I agree... you should have at least been credited somehow.
M
Old Jul 15, 2016 | 05:48 PM
chazman's Avatar
Axle/Gears: BW 3.45
Here you go. Battery got dirty not being in the car the past almost couple of decades.
Old Jul 15, 2016 | 05:49 PM
Originally Posted by skylark3300v6
Drew -
Excellent! Now just to figure out how to get one printed and stuck on the battery...
Props for giving credit where due, too often work that's posted online gets plagiarized without so much as a source credit.
BTW, Walmart's batteries are flat tops now, like the ones in this thread. They aren't exactly the same case are the real deal, but close enough for our purposes I suppose.
Old Jul 15, 2016 | 05:53 PM
Thanks Drew! I just ordered some vinyl label stock and printed it on my color laser printer.
I think Staples can do this too. Then just cut peel and stick!
Old Jul 15, 2016 | 09:44 PM
Stuart S's Avatar
skylark3300v6,what did you do to make the white battery case/surround? Any more pictures of that?
Old Jul 15, 2016 | 09:56 PM
All I did was paint the body of the battery white.
Used a hacksaw to cut the handle lugs off, then sanded the plastic down flat. Used 3M surface cleaner to prep for paint, masked the cap off, and then Krylon Fusion gloss white for the sides.
Old Jul 15, 2016 | 10:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
Man,I'd love to have a Green Dot,do you sell them?
Old Jul 16, 2016 | 07:33 AM
Sell... No.
But I would be happy to print you one for free! Just send me your address.
