'91/'92 highrise Z28 spoiler mod, *Finished, See Post #121!*
Old Jul 6, 2016 | 03:02 PM
  #151
Re: '91/'92 highrise Z28 spoiler mod, *Finished, See Post #121!*
So I'm working on putting the spoiler on my Camaro. I'm taking a slightly different approach than you with the sides and making the fenders taller. I was wondering if you used all four pairs of the spoiler's mounting studs or did you remove the outers and only use the inside pairs?
Old Dec 4, 2016 | 09:15 PM
  #152
The OP seems have left the thirdgen community. Thought I'd post pictures of my finished product. I took the high rise spoiler mod a step further and actually raised and refinished the top of the rear fenders, raised the front of the rear fenders (portion by the back of the door) and then extended down the side pillars of the spoiler. It's a big undertaking, I don't advise you do this unless you are a competent welder and body experience. I also wouldn't even think about asking a body shop to do this as the bill would be enormous.
Old Dec 4, 2016 | 09:21 PM
  #153
When you remove the urethane wrap around spoiler pieces you'll see why they wanted to cover it up with a simple cap...
The last picture shows the height difference between the top of the fenders and the trunk lid is measured at 1/4" WITHOUT the weatherstripping. With the weatherstripping it goes up to 3/8 - 1/2". The water channel also has a big and uneven gap.
Old Dec 4, 2016 | 09:24 PM
  #154
The expanding foam was only to hold the top in place while I welded in the metal for the sides. I didn't use fiberglass on the sides.
Old Dec 4, 2016 | 09:28 PM
  #155
Rough sanding the first batch of filler
You can see how the front of the fender had to be raised and a new cap created since the urethane piece capped it before. The tonneau cover isn't latched in the picture
Old Dec 4, 2016 | 09:34 PM
  #156
how the spoiler fits when put in place, so you have to extend it down.
Finish creating the sides with fiberglass, do your filler work and paint.
Old Mar 15, 2017 | 07:13 PM
  #157
1992 Trans Am's Avatar
Engine: 5.0L 305ci TPI
Axle/Gears: 3.08
That is really sweet, Tibo!
Old Mar 15, 2017 | 08:59 PM
  #158
Thanks, if you have welding and bodywork experience it's not hard, just time consuming.
Old Sep 4, 2018 | 09:40 PM
  #159
shaggyowl's Avatar
Car: 1991 Z28 Convertible
Engine: 5.0 V8
Transmission: auto
Re: '91/'92 highrise Z28 spoiler mod, started fiberglass 3/5/11
Do the bolt holes line up at all when going from the factory spoiler to the wing?
Old Sep 4, 2018 | 09:48 PM
  #160
No. I had to weld shut the convertible's stock spoiler mounting holes and drill new holes for the spoiler. I cover it some detail in my build thread.
Frozer!!!
Jan 19, 2024 04:55 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
snakeshooter
Aug 22, 2015 07:06 AM
LilHot
Aug 19, 2015 10:02 AM
