Original Decals location.
Old Dec 12, 2016 | 06:58 PM
  #151
Re: Original Decals location.
Originally Posted by CPC Norwood
Trying to determine the correct color for the paper tag attached to the rear coil springs for 1987 this would be spring NNL. I think it was originally White or Beige??
Any assistance would be appreciated.
Originally Posted by scottmoyer
They were white.
If I had to name the color, I'd call it yellow.
Old Dec 13, 2016 | 01:54 PM
  #152
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Agreed. It's hard to get the exact color. Bright white is not the correct color, but more of a yellowish white is what mine look like now. Not sure if that's just aged, or if that's the actual color. Kind of like the tag found on the brake fluid reservoir shown above. Or like the master cylinder tag that was pictured in another thread.
Old Dec 13, 2016 | 02:50 PM
  #153
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Originally Posted by Polo Z03
How about the "Customer Satisfaction System Certification"? . . . Or the green dot?
Any advice on what to use to "re-apply" the loose corner of my door jamb decal above?
As for the Green Dot.....It was probably a dot assigned to a team at the servicing Dealer. Our Bronco when new was assigned a Blue Dot...for the blue team.
Maybe...IDK
Old Dec 14, 2016 | 08:06 PM
  #154
CPC Norwood's Avatar
I have the reproduction for the rear springs ready.
For any one who is interested the NL is size 49 font in gill sands MT condensed. The 10018091 is size 15 font (bold) impact.
All MS WORD
Old Dec 14, 2016 | 09:56 PM
  #155
Nice! But the color is wrong.
Go on Ebay and search for NOS springs. Even newer GM cars still use yellow on the tags. I've literally got a pile of used springs out back, three or four sets worth. All the tags are consistently yellow.
Old Dec 15, 2016 | 05:05 AM
  #156
Thanks...they can be done on any color now. More of an off white? , beige or a pale yellow?. Scott says more of an off white.
Old Dec 15, 2016 | 08:16 AM
  #157
Pukey **** Yellow?
These are NOS 4th gen springs, but you get the idea. Do a Google image search for "GM nos coil springs" for more examples.
Old Dec 15, 2016 | 08:54 AM
  #158
Here is the problem... Here is the originals still on the spring with no flash applied.
I am not seeing yellow?? Need opinions.. Thanks!
Old Dec 15, 2016 | 08:57 AM
  #159
Another... Perhaps a very light yellow?
Old Dec 15, 2016 | 09:02 AM
  #160
One more.
Old Dec 15, 2016 | 10:21 AM
  #161
I have a 20k mile set of springs, shocks and struts from a 92 formula 350 at home. Thinking the tags aren't yellow on those but I'll try to dig them out tonight for more examples for us to learn from.
Old Dec 15, 2016 | 04:53 PM
  #162
I think we are all correct to a extent.
Here are some 92 FORMULA 350 springs
Fronts are yellow, rears are white/dirty off white
Here are 2 pix of a low mile car, yellow front, white(ish) rear.
Rear
Front
Think this was a 89 formula 350, can barely see the yellow front spring tag and also the light blue swaybar tag
Old Dec 15, 2016 | 05:18 PM
  #163
GASPEDDLER's Avatar
Here are some pics of my driver's side spring, looks like an off white.
Old Dec 15, 2016 | 06:29 PM
  #164
Thanks to all! I think my gut was telling me it was a light beige/off white. That's what I am going with then!
Old Dec 15, 2016 | 08:24 PM
  #165
One thing to keep in mind is that the rear springs (and their tags) are much more exposed than the fronts. By nature of their position, they catch all the water spray from the front tires. It's not too much of a stretch to imagine why they could be more discolored than the fronts that are considerably more shielded.
I'll have to take a closer look at my mountain of springs next time I'm out there, assuming it ever warms up! It's entirely possible that I've always assumed all four corners are the same color, due in part to dirt, undercoating overspray, fading, etc.
Old Dec 15, 2016 | 09:59 PM
  #166
GASPEDDLER's Avatar
Here are some pics of my passenger side and it definitely looks like a faded yellow.
Old Dec 15, 2016 | 10:14 PM
  #167
That's kinda like newspaper that turns yellow from being in the light
Old Dec 16, 2016 | 06:55 AM
  #168
I took Drew's advice and looked. I think I found our color.
Definite NOS and likely indicative of the color used: http://www.ebay.com/itm/1997-2003-PONTIAC-GRAND-PRIX-REAR-SUSPENSION-COIL-SPRING-GENUINE-GM-NOS-H-2-BF/122170933410?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38530%26meid%3De21e6b0ecfe8498ba61bd5b25c09d1a7%26pid%3D100005%26rk%3D2%26rkt%3D2%26sd%3D121205736151
Old Dec 17, 2016 | 09:01 AM
  #169
Has anyone noted a factory paper tag on the driveshaft of a late third gen?
I know they used tags on the prop shaft in 1993.
Thanks in advance!
Old Dec 17, 2016 | 09:23 AM
  #170
Never seen that, guessing you are talking about steel DS. The aluminum ones have a plastic like tag on them that has all kinds of info.
Old Dec 17, 2016 | 09:45 AM
  #171
Yes Steel. The inspection marks, (1987 NOR) Dark green, Coral (pink) and Light green on the U Joints -were very close to what was used on my 1993 (St Therese) and it (93) had a paper date tag on it too.
Old Dec 19, 2016 | 12:01 PM
  #172
better spring pictures
Rear and front 4thgen
Rear
front
Old Dec 19, 2016 | 04:35 PM
  #173
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
More pics from your **** collection Tony?
Old Dec 19, 2016 | 06:24 PM
  #174
Being married does it..
Old Dec 22, 2016 | 04:29 PM
  #175
Polo Z03's Avatar
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Maybe...IDK
My Camaro also had this green dot on the back of the rear view mirror and next to the rear key hole . .
Old Dec 22, 2016 | 04:33 PM
  #176
Polo Z03's Avatar
Here's my NNL rear spring tag . . just under 17,000 miles . . . looks creamy white to me . .
Old Jan 11, 2017 | 07:34 AM
  #177
These are my installed reproductions-posting these here for illustrative purposes only. These are not original NOS springs these are restored.
Old Jan 11, 2017 | 08:17 AM
  #178
They look waaaay to nice, better tear the ends of them!
Old Jan 11, 2017 | 08:29 AM
  #179
I tore them off as the manufacturing plant did with a serrated edge!
Old Jan 15, 2017 | 04:14 PM
  #180
Looking for a good door decal measurement for decal placement on 87-90 formula 350. Any Original paint formulas get me a measurement from the bottom of the door to bottom of the decal?
Old Jan 16, 2017 | 01:58 PM
  #181
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Tony,
That stupid decal can be almost anywhere below the center of the door
Honestly My Formula 350 Convertible is TOO HIGH, and that is how it came from the factory, it is almost in the center of the door top to bottom.
I used to have some measurements I just don't have them on hand.
Old Jan 16, 2017 | 05:58 PM
  #182
I know! On the solid color cars they just seem to be anywhere on the door. However, I have noticed, on the sliver bottom cars with the stripe, they seem to be more accurately located. That's what I'd like to get a measurement from.
Old Feb 9, 2017 | 09:19 AM
  #183
Has anyone reproduced the strut/shock 2 letter code sticky back paper tags yet?
Old Feb 11, 2017 | 12:59 PM
  #184
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
I did for my TTA ....
Old Feb 11, 2017 | 01:49 PM
  #185
I'm sure everyone has their own way of doing these, but it might help each other out if we share what font and maybe even size matches best. It'd also be nice to know what materials people are using, like paper, inkjet vs laser jet vs hiring a pro printer. I'm hesitant to go too far into posting exact templates to be printed since A) they'll be hijacked and end up on Ebay and B) we'll start seeing them stuck all over the wrong cars.
So far I've taken the best photos I can find, then resize them in Photoshop, approximate the colors, then using a new blank layer, I paint a duplicate over the original to get rid of the artifacts, damage, and make for a sharper image. It just takes awhile to get the lettering sized right, then find the right font, etc.
I had a few ready to print on good paper, I backed them up to another drive, and then in typical fashion that drive failed. LOL Maybe I should have shared my work afterall. LOL
Old Feb 11, 2017 | 02:41 PM
  #186
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
I did a lot of research and people (TTA community) contributed with photos and dimensions needed .... had a guy do them and print (to order) for us ... so we could have these available and people could just go and order what they needed ... we got I would say 90% of everything on a TTA done and some ordered what they needed however at one point GM called the guy and asked for license fees to be paid upfront for future orders so needles to say something done for the hobbyist he could not afford so he stopped doing them ... myself and others spent a lot of time making them available however all that work is gone .... I do have all the information I collected and I even did other decals for my own use and professionally printed and die cut to correct size (so not a regular inkjet printer at home) one of them being the correct battery decal ... then someone bought a couple from me copied and printed them (you can tell as his is much fuzzier being a scan and not crisp design like my original) put them on ebay and sold a lot of them I would say he netted easily $1000 USD on my time and investment.
I'm all for sharing and contributing to the community if its a 2 way street and if people don't take advantage of it .... in the end its a hobby and if everyone do contribute we can get so much more out of it and everyone put their fair share into it.
This is what I would love to see done at some point:
http://fierostuff.com/fiero-stickers...rder-stickers/
But with pretty much anything you can imagine for our 3rd Gens.
Old Feb 11, 2017 | 02:53 PM
  #187
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Just a few examples of what we had done .... there's another 20+
Old Feb 12, 2017 | 09:15 AM
  #188
Here are a few prop valve codes I have to add to your collection.
Lost a lot of my original code decal pix in the great hard drive crash of '15.. but I do need shock/strut an spring decal codes for a 92 formula (think all the formulas are the same)
I also need both 9bolt diff code decals. 8EQ(?) and 9EQ
Old Oct 30, 2017 | 10:48 AM
  #189
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Really cool thread!!!
Old Dec 14, 2017 | 01:42 PM
  #190
jstites's Avatar
Looking for the FX decal that is on the front of the master cylinder of a 87 GTA. Is anyone pe-poping those?
Old Dec 14, 2017 | 02:06 PM
  #191
You found the site, welcome aboard!
Old Dec 14, 2017 | 02:10 PM
  #192
jstites's Avatar
Been here for some time now, just havent posted......thx
Old Jan 2, 2018 | 03:38 PM
  #193
You (or anyone) happen to have any info about whats on the white decal on the spoke do you? supplier part number decal like on the crosslace wheels maybe?
Old Jan 3, 2018 | 10:35 AM
  #194
okfoz's Avatar
About the only thing I can think of is it is a part number or some identifier. Might be simply "Front" or "Rear" too bad the image is not clear enough...
What is really interesting is the white covering on the T-top, not all cars have it, but the white car behind the blue car almost looks like the T-top was painted... Matches the white almost exactly.
Old Jan 3, 2018 | 12:00 PM
  #195
The TTops had a protective covering on them when shipped from the supplier to help prevent scratching.
Old Jan 29, 2018 | 06:51 AM
  #196
Fireblood83's Avatar
Car: 82 Trans Am
Engine: 305 ci V8 4-bbl
Transmission: TH200C
Axle/Gears: 10 Bolt/3.23 posi
Thanks for the info. Is that a OEM spare?
Old Jan 29, 2018 | 06:59 AM
  #197
Nah, that's prob an Ebay or who knows where I got the pic through the yrs.
Old Jan 29, 2018 | 07:09 AM
  #198
PurelyPMD's Avatar
LF on my 91 1LE Z28.
Old Jan 29, 2018 | 04:34 PM
  #199
Any chance you can get a clear scan of that tag? Could use an example to make a repro for my Formula. Still have the LF stamped valve, but the label is long gone.
One of these days I need to sit down and repro all the vacuum line tags, and the tags for the throttle cables, etc. Most of that stuff was removed by me over the years as the paper and glue gave up and they started falling off. No decals look better than shredded decals.
Old Jan 30, 2018 | 06:59 AM
  #200
Think I have a few LFs floating around as well, just need to get to garage a bit more.
