Third Gen Dual Exhaust Picture Collection
Old Feb 25, 2017 | 11:47 AM
  #551
skinny z's Avatar
Re: Third Gen Dual Exhaust Picture Collection
Is that Holley/Hooker's crossmember?
Is there a part number for that crossmember?
Old Feb 26, 2017 | 08:50 AM
  #552
mw66nova's Avatar
Car: camaro sportcoupe
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yes.
https://www.summitracing.com/parts/h...FYxMDQod6tMNdA
Old Feb 26, 2017 | 11:26 AM
  #553
skinny z's Avatar
That's the crossmember I'll be getting to allow my Vette cased 4L60 to be installed behind a Gen 1 SBC. Thing is Holley, through my conversations with Toddoky, says that particular crossmember requires the use of their specific engine mounts, which moves the LS based engine forward. That way the LS T56 (as opposed to the LT1 T56) can be used without modification.
The crossmember is also said to work with a Gen 1 SBC and a LT1 spec'd T56. This closely approximates the length of a short tail TH400 (which coincidentally is the approximate mounting length of a 4L60 using a b-body extension housing with mount). This is done with the factory engine mounts and mount locations.
In his description. gixxer said his LS engine is in the stock Gen 1 location. Something isn't adding up.
Not meaning to hijack or anything it's just that this is the first time I've seen this crossmember used and I have questions regarding the fitment.
Old Feb 26, 2017 | 07:41 PM
  #554
toddoky's Avatar
Don't over-think things here skinnyz, the Hooker third-gen LS engine mounting brackets moves the stock SBC engine/transmission mating plane forward by only about 5/8", so the Hooker crossmember will ending up working with some other combinations of aftermarket parts. The problem lies in the fact that there's no way to judge compatibility without physically installing the parts as many aftermarket parts have geometry that is other than what is advertised and the Hooker crossmember center beam comes very close to the case of the T56 even when used as designed with the Hooker engine brackets. In your case, you'll have much more leeway as your transmission pan will come nowhere near the center beam.
Old Feb 27, 2017 | 09:32 AM
  #555
skinny z's Avatar
Not so much over-thinking as it is thinking it through.
The internet provides so much information, some of which may be a little misleading, that I'm trying to approach this from as many angles as I can.
Based on our other conversations, I'm pretty sure what I'm getting in to. Modifications to the crossmember (to work with a stock location Gen 1 SBC and a "B-body" 4L60 (Vette case with a b-body extension housing) are, I think inevitable, however the changes should be very modest. As you suggested Tod, perhaps only slotting the holes in the crossmember will be needed. The exhaust on the other hand, being a unique piece in my case, is the other variable to deal with. There looks to be plenty of clearance with the high arches of the Hooker crossmember but I won't know for certain until I'm under the car working on the fitment.
Thanks again toddoky for your input. It's very much appreciated.
Old Feb 27, 2017 | 12:06 PM
  #556
toddoky's Avatar
Here's a photo I dug out of my files that you might find helpful...it shows the Hooker 3rd-gen transmission crossmember and dual exhaust system installed in a SB Chevy/LT1 T56 application. It works in this instance because the LT1 T56 transmission is 5/8" shorter (bellhousing face to mount) than the LS1 T56 transmission.
Old Feb 27, 2017 | 12:26 PM
  #557
skinny z's Avatar
That IS a helpful picture.
And based off of that bit of information, (the LT1 T56 transmission is 5/8" shorter), that means that my transmission rear mount will be 1 9/16" further back (than that of the LT1 T56).
LT1 T56 bellhousing to rear mount at 26 3/8". B-body 4L60 bellhousing to rear mount, 27 15/16" (if the internet's description of the B body 4L60 is the same as that of a TH400)
Now, having had a chance to examine a few of these installations, I can see a few problems going forward. While I can adapt an offset mount to capture the locations between the crossmember and the transmission, I can't see how my existing y-pipe will fit. Unfortunately for me, where my y-pipe transitions to the merge pipe is directly under the Hooker crossmember. It's not going to fit with out a redo or replacement.
Attached Thumbnails Third Gen Dual Exhaust Picture Collection-t56-measurments.jpg   Third Gen Dual Exhaust Picture Collection-transmeasurements.jpg   Third Gen Dual Exhaust Picture Collection-new-mount.jpg
Old Feb 27, 2017 | 12:57 PM
  #558
toddoky's Avatar
The images you posted are examples of the erroneous information that can be found online...the actual mount distances for those transmissions from the bellhousing mating surface is as follows:
LT1 T56- 25.992"
LS1 T56- 26.617"
TH400 with 4" extension housing- 26.875", same as the 200R4 transmission
I know these dimensions to be correct as I use them in an almost daily capacity to design transmission crossmembers for the various LS swap systems I develop...I've measured these transmissions and 13 others with a 36" vernier height gauge on top of a dead flat table.
Yes, your Y-pipe would be problematic from a compatibility standpoint.
Old Feb 27, 2017 | 01:17 PM
  #559
skinny z's Avatar
Originally Posted by toddoky
LT1 T56- 25.992"
LS1 T56- 26.617"
And THAT is the kind of information that I like to see.
Much appreciated.
A now to figure what to do about that y-pipe.
Old Mar 18, 2017 | 11:28 AM
  #560
Danny_VXH's Avatar
And its done. My true dual stainless system.
He he.. alright.
Old Mar 18, 2017 | 06:05 PM
  #561
mw66nova's Avatar
my new system is taking shape
working on the other side still and waiting on parts.
Old Mar 18, 2017 | 08:52 PM
  #562
Did you shop RVtrader for those exhaust tips?
Old May 25, 2017 | 12:48 PM
  #563
jwtaylor's Avatar
Car: 1983 Camaro sport coupe
Engine: The original 305
Transmission: Original 700r4
Axle/Gears: 10 bolt not sure what geats
Originally Posted by Iroc Adio
Hooker Super Comps with custom hedman s tensions and flowmaster delta force race mufflers.I have about 3.5" of clearance at the s tension and 4" at the mufflers.
you wouldn't happen to have or be able to get a better picture of how you mounted the read exhaust hangers.
Old May 25, 2017 | 03:28 PM
  #564
chad pickens's Avatar
this is a picture from when i was mocking up the exhaust about a year ago
Old Jun 4, 2017 | 08:29 PM
  #565
stanley 383's Avatar
Car: 91 rs
Engine: 434 stroked v7 supercharger
Transmission: mad dogg 700r4
3in dual exhaust long tubes
Old Jun 7, 2017 | 05:20 PM
  #566
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
He he.. alright.
That's a very nice looking system. One bit of criticism, perhaps more of a caution. Those tips look like they end up really close to the ground and beyond the rear bumper. You'll need to be careful backing up to curbs. You'll cry if you run one of those tips into the concrete and tweak your system. May find you'll be happier with tips more like OE.
Just a thought.
Old Jun 20, 2017 | 10:30 AM
  #567
LS2Swapped92's Avatar
Figure I would add mine too. Just completed this year before Thirdgen Expo.
1 7/8" to 3" collector SS headers by hawks.
Custom fabbed exhaust using vbands from front to rear
Key difference is I went over the axle on both sides
Thread here:
https://www.thirdgen.org/forums/exha...axle-each.html
Idle Only
Idle - Light Throttle
Burnout @ Thirdgen Expo
Attached Thumbnails Third Gen Dual Exhaust Picture Collection-20170513_183229-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_183316-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_183424-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_183446-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_183512-1288.jpg
Third Gen Dual Exhaust Picture Collection-20170513_183547-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_183559-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_183611-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170513_185529-1288.jpg   Third Gen Dual Exhaust Picture Collection-20170514_132716-1288.jpg
Old Jun 24, 2017 | 12:03 PM
  #568
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
^Looks and sounds great!
Old Jun 25, 2017 | 11:11 AM
  #569
mw66nova's Avatar
new dual 4" exhaust almost complete.
Old Jul 5, 2017 | 08:48 AM
  #570
fuken.max's Avatar
Car: 1986 z28 383 camaro
wow nice!
Old Jul 9, 2017 | 08:03 PM
  #571
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Texas Speed Performance is now offering this dual exhaust kit for the fourthgen for $500
Old Aug 12, 2017 | 10:32 PM
  #572
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Thread here:
Idle Only
https://www.youtube.com/watch?v=Odd0w8PfS1Y&t=12s
https://www.youtube.com/watch?v=sT2mGFPp6d8
https://www.youtube.com/watch?v=5HFM_o7uJJU
What's the extra turnbuckle near the driver panhard bar mount for?
Old Sep 16, 2017 | 12:30 PM
  #573
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
12 pages, and i think i saw one system with cats.
Old Oct 10, 2017 | 04:57 PM
  #574
TeamPoisonOil's Avatar
I don't see this on your website
Old Oct 10, 2017 | 06:18 PM
  #575
Danny_VXH's Avatar
Just a thought.
I know you got a point mate, however i wanted it to look like this. It had bolt on tips when i bought it which faced down although not as much as these. I'll be very carefull with it to be honest. If i find it to troublesome in the future i'll change it. However as for now, i think it can get away with it. I'm also creating some portable ramps for in the trunk which i'll be able to use to get over certain speedbumps if needed. However i mostly will drive it on freeways and avoid speedbump infested areas as much as possible.
Won them at an ebay auction mate, not sure where they originate from. I was looking for a set like this for a while.
Old Oct 10, 2017 | 07:36 PM
  #576
mw66nova's Avatar
all done!
Old Oct 11, 2017 | 07:48 PM
  #577
skinny z's Avatar
THAT is interesting. And modestly priced too.
Those headers remind of the Super Comps I have on the big block TA. Exiting more towards the rockers and away from the transmission than a typical header. Not that it would matter in my case. I'd have to build the intermediate pipes from the headers to the "X" anyway.
Do you have a link to that part? I couldn't find it on their web site.
Old Oct 11, 2017 | 08:54 PM
  #578
mw66nova's Avatar
that's the normal layout for the 4th gens. the inner subframe horns go outward instead of inward on those cars.
Old Oct 11, 2017 | 09:08 PM
  #579
skinny z's Avatar
How about the rest of the architecture? Would it be easily adaptable to the 3rd gen?
Old Oct 11, 2017 | 09:40 PM
  #580
AF Chief's Avatar
Sweet!!
Old Oct 12, 2017 | 08:39 PM
  #581
mw66nova's Avatar
after the transmission crossmember, they're essentially identical.
Old Oct 12, 2017 | 09:50 PM
  #582
skinny z's Avatar
Well, that gives another option as far a dual exhaust is concerned.
Old Oct 13, 2017 | 08:12 AM
  #583
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
That's interesting. I wasn't aware 3rd and 4th were the same after the crossmember going back.
So using a 4th gen catback will work in a third gen?
Old Oct 13, 2017 | 08:35 AM
  #584
mw66nova's Avatar
yes. in fact, we have a magnaflow catback from a buddy's 2002 formula on my little brother's 5.3 swapped 89 iroc. there are a few details that have to be addressed concerning hangers, but it's not a lot of work.
Old Oct 13, 2017 | 09:11 AM
  #585
Ozz1967's Avatar
Car: 1984 Trans Am
Well, as mentioned earlier, that really opens up options for exhaust then.
Old Oct 27, 2017 | 01:19 PM
  #586
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I'm curious,has somebody tested these to 3-gen?
Old Oct 28, 2017 | 07:13 PM
  #587
mw66nova's Avatar
as mentioned above, you'll have to modify it from x-pipe forward, and you will need to do some hanger moving in the back.
Old Feb 23, 2018 | 03:51 PM
  #588
irocdanne's Avatar
Car: 87 Iroc
Engine: Ls 428 F2
Transmission: Th400
Axle/Gears: 3.70
I have dual 3" from the headers. It would be really nice with dual 3,5" but its very tight to get that all the way back with TA and stock fuel tank. But I think the 3" system steals some power now when were at 1000+ hp. Maybe some oval pipes can make it happen :P
Old Feb 23, 2018 | 03:52 PM
  #589
irocdanne's Avatar
Car: 87 Iroc
Engine: Ls 428 F2
Transmission: Th400
Axle/Gears: 3.70
The pics are pretty old, from when we had sbc in it. Now with Ls/procharger it has some full flow magnafuels at the back instead
Old Feb 25, 2018 | 11:25 AM
  #590
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
How is the ground clearance with that
Old Dec 20, 2018 | 09:42 AM
  #591
mccamaro91's Avatar
God this forum makes me miss my camaro. This video is before I added the quad tips but I LOVED the growl of my flowmaster:
Old Dec 20, 2018 | 09:46 AM
  #592
mccamaro91's Avatar
And another vid of it firing up:
Old Dec 20, 2018 | 10:38 AM
  #593
Edsiroc's Avatar
Car: 1989 Camaro, 1989 Firebird
Engine: 5.0 TPI, 5.7 TPI
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.23
This thread is very helpful. Here’s a picture of my true duals using hawks crossmember, eBay headers that come with the two pipes and ugly y merge that I didn’t not use with spin tech mufflers. Anyone recommend other mufflers? Thanks!
Old Feb 1, 2019 | 03:05 PM
  #594
4valvemach's Avatar
Car: 04 mach1
Dual 2 1/2 exhaust mostly straights and 45 degree bends just the cheap stuff from parts store.It was same clearance as factory exhaust from the ground when I was done.
Old Feb 1, 2019 | 03:25 PM
  #595
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I live the dual two on the left routing.
Old Feb 1, 2019 | 04:21 PM
  #596
4valvemach's Avatar
Car: 04 mach1
Kept the pipes out of sight
I tried to post the YouTube video but can't get link to work?
https://youtu.be/bZUKEibLpJQ
Old Mar 9, 2019 | 10:41 PM
  #597
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
1989 GTA
Old Mar 9, 2019 | 10:45 PM
  #598
427seven's Avatar
All stainless 3", all v band
Old Mar 10, 2019 | 10:58 AM
  #599
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Nice work 427seven!
I like the routing. Nice to see the canton (242-T?) works with the stock crossmember and that the exhaust passes so well in that area!
Using a heat wrap or blanket to keep the heat off the oil pan?
What does the "bump" look like on the inside with the floor board/back seat area?
Old Mar 10, 2019 | 02:36 PM
  #600
427seven's Avatar
It is routed that way to equalize the lengths and the bump is under the seat rails which are modified Corbeau units and had to be "fitted" bc of the hump. Nothing major, just a little notching with a grinder, and I had to paint them to match the seats anyway. The heat shield had to be put in. Even before this exhaust system I had a mild steel 2.5" system I used for the initial design, and the power plant puts out so much energy that it was just HOT. This shield cut the heat in half, so I decided to add it to the CANTON 15-244. I've "cruised" the car in stoplight traffic for 4 hours and the temps don't budge, always right at 185-190.
