This is for a used v-7 ysi. It was on a 3rd gen firebird running mid 8's. Producing 26-29 lbs. no shaft play, no chip in fins. All in great working condition. The head unit was bob kurgan's personal back up head unit.
2 sets of pulleys. One is a 10 rib belt and the other is for a cog belt. Asp pulleys . I have 2 rib belts. In 2 years it never tossed a belt due to the extra engineering that has gone into the system.
Custom brackets that added a pulley tensioner to gain more tension on the belt for less slipping. A bracket from the head unit bracket to the back of the head was added for additional strength. Custom pieces were machined to allow the use of a kurgan brace to add for additional belt tension and to take side load off of the crank. Everything has been spun balanced to ensure no issues while running. The brackets are built to be used with a crank trigger and a motor plate. A spacer is needed if not using a motor plate. ( will supply) . A extreme velocity carb with o-ring, polished. A vortech blow off valve with some piping, with a gm air intake temp sensor. All the correct nuts and bolts you'll need to bolt it together.
$3500 obo
Located in Darien wi, 53114
I will ship, but it's on your dime.
Any additional information wanted please feel free to call text or me. 262 745 2432
A over all view of what you'll be getting Vortech blow off valve Cog belt pulleys Kurgan brace Lower crank pulley along with water pump and altanator pulley Asp pulley and custom spacer for kurgan Added tenstioner pulley No shaft play or dings in blades
Reason: Forgot price
Thanks pancherj. It's a great blower with a lot of additional research and development to make it work consistent and make it very reliable. Street friendly, in fact air intake temps would go down when cruising.
