[WI] Vortech v-7 ysi super charger
Old Jul 10, 2017 | 07:08 AM
scaryjerry's Avatar
Transmission: t-5
This is for a used v-7 ysi. It was on a 3rd gen firebird running mid 8's. Producing 26-29 lbs. no shaft play, no chip in fins. All in great working condition. The head unit was bob kurgan's personal back up head unit.
2 sets of pulleys. One is a 10 rib belt and the other is for a cog belt. Asp pulleys . I have 2 rib belts. In 2 years it never tossed a belt due to the extra engineering that has gone into the system.
Custom brackets that added a pulley tensioner to gain more tension on the belt for less slipping. A bracket from the head unit bracket to the back of the head was added for additional strength. Custom pieces were machined to allow the use of a kurgan brace to add for additional belt tension and to take side load off of the crank. Everything has been spun balanced to ensure no issues while running. The brackets are built to be used with a crank trigger and a motor plate. A spacer is needed if not using a motor plate. ( will supply) . A extreme velocity carb with o-ring, polished. A vortech blow off valve with some piping, with a gm air intake temp sensor. All the correct nuts and bolts you'll need to bolt it together.
$3500 obo
Located in Darien wi, 53114
I will ship, but it's on your dime.
Any additional information wanted please feel free to call text or me. 262 745 2432
A over all view of what you'll be getting
Vortech blow off valve
Cog belt pulleys
Kurgan brace
Lower crank pulley along with water pump and altanator pulley
Asp pulley and custom spacer for kurgan
Added tenstioner pulley
No shaft play or dings in blades
Old Jul 10, 2017 | 04:06 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Vortech v-7 ysi super charger
No price listed -
Old Jul 11, 2017 | 05:30 AM
scaryjerry's Avatar
Transmission: t-5
I am asking $3500 obo. I also added it to the post
Old Jul 11, 2017 | 06:04 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Ooh baby am I tempted! That's a nice setup.
Old Jul 14, 2017 | 07:14 PM
scaryjerry's Avatar
Transmission: t-5
Thanks pancherj. It's a great blower with a lot of additional research and development to make it work consistent and make it very reliable. Street friendly, in fact air intake temps would go down when cruising.
Old Jul 16, 2017 | 12:12 PM
pancherj's Avatar
Car: 1990 IROC
Any wiggle room on the price? Shoot me a PM if you're interested. Thanks!
Old Jul 24, 2017 | 10:12 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
can you post a pic of it from the front so i can see the entire system of brackets/pulleys?
Old Jul 24, 2017 | 10:20 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
are those 35mm or 50 mm cogs? what are the # of ribs on the cog pulleys?
Old Jul 24, 2017 | 11:25 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I see a chip on the fin i the head on shot BTW.
Would be very unhappy to see this after laying out that much $$$$ and feeling lied to.
Old Oct 9, 2017 | 11:33 AM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
Still have the blower?
