What did the previous owner do to my windshield washer fluid motor?
Old Aug 9, 2017 | 04:45 PM
jeremyb1988's Avatar
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Hey guys...so bought this car 5 months ago from a guy. Okay what's up with this windshield washer fluid motor? I think the nozzle at the bottom is missing?
Also I see it looks like u can buy just the WASHER fluid motor from hawks or Ricks camaro. Is that as easy as popping the cover? Also it looks like he no passed the nozzle or some crazy stuff...I need help haha
Old Aug 9, 2017 | 06:51 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: What did the previous owner do to my windshield washer fluid motor?
Don't Know Why He Ran That Hose Directly Through The Firewall. Or Is It Just Leaning Against It.
Old Aug 9, 2017 | 07:07 PM
On Probation
Cool man!...could u find it in ur heart to take pics and show me how it's supposed to be set up ???
Old Aug 10, 2017 | 12:48 AM
No need to order a replacement pump. GM used the same part on many cars of the era. Most autoparts stores will have them in stock.
The process of replacing the pump isn't hard. The little metal clip at the bottom needs to be popped out. IIRC don't pry it, but push up underneath and it'll release. Then the pump just pulls out of the wiper motor.
The new pump will have two hose barbs, an in and an out. The in goes to the washer fluid tank, out to the line through the firewall (actually cowl fwiw).
Old Aug 10, 2017 | 02:43 AM
It looks like the pump is MISSING. It plugs into this cavity (see pic).
I believe RockAuto has them. Just plug the new one in and connect the hoses.
Attached Thumbnails What did the previous owner do to my windshield washer fluid motor?-washer.jpg
Old Aug 10, 2017 | 06:19 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
windshield washer pump and motor
broken bits on the windshield washer pump and motor
what noemissions said, it just plugs in, I replaced mine a couple of months ago. In my opinion it was a lot easier to see what was going on with it out of the car, after messing with it a bit I figured out that that "cartridge" for lack of better terms just plugs in.
Old Aug 10, 2017 | 10:01 AM
gt4373's Avatar
Old Aug 10, 2017 | 01:01 PM
On Probation
Thanks guys! U guys are my hero's I love this site!!!
Old Aug 10, 2017 | 01:03 PM
On Probation
I guess I need to buy some extra line then, is there some filter or something that goes from the output to ur windshield right after the nozzel??? And if so where to get those, advanced?
Old Aug 15, 2017 | 04:18 PM
On Probation
Hey guys...I read online something about a check valve after these things? Is that so, I just bought a new pump from O-reillys and its coming in tomorrow morning . I do see some sort of check valve on mine I believe right after the output line...
Old Aug 15, 2017 | 04:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Your 2nd pic shows the check valve,
Old Aug 15, 2017 | 05:28 PM
On Probation
Does that look to be in the right flow Direction?
Old Aug 15, 2017 | 05:42 PM
On Probation
Also do these pumps need to be primed how's that done? Take washer fluid from one end and blow it to the pump???
Old Aug 15, 2017 | 08:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yes.
No.
Old Aug 15, 2017 | 09:35 PM
On Probation
Thanks!
Old Aug 16, 2017 | 05:51 PM
On Probation
Hey guys all done! Got a Trick pump from oreillys for like 17 bucks some new line and what not and new fluid! Works great! I thought the fluid would spray hard onto the windshield like most cars...it kinda does none of that lol...but I guess that's 80s technology for u huh!
Old Aug 17, 2017 | 01:31 AM
Peter Bowen's Avatar
This is better... at high speed you want the washer fluid on your windshield and not the guy behind you. I wish more cars did it this way instead of using those nozzles on the hood. It's also nice not to have any nozzles to have to clean and wax around.
Old Aug 17, 2017 | 02:38 AM
Old Apr 4, 2019 | 09:59 AM
babyelephant's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
I just replaced the pump in my car and discovered this check valve was also broken, splitted. I discarded it and mounted up the new pump without it. What is the check valve's function? Recommended to get a replacement valve or leave it as is?
Old Apr 9, 2019 | 06:31 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I believe its suppose to keep the water from running back into the reservoir so the pump doesn't cavitate when you use the washer function.
Old Apr 10, 2019 | 04:16 AM
Engine: 5.7 TPI
Thanks for clarifying. I will order a replacement valve.
Old May 28, 2019 | 09:41 AM
rydeauto's Avatar
Have an 87 GTA and need the housing or cover for the wiper motor. Any ideas or work arounds...
