Found these seatbelt sleeves
Old Nov 2, 2017 | 07:16 PM
Sdallaire's Avatar
Car: 1987 Chevrolet CAMARO IROC-Z
Engine: 5.7 crate engine 300hp
Transmission: TH700R4
I feel lucky!!
Found these band new seatbelt receiver sleeves on Internet.
30$
Can't wait to install them!!
Old Nov 2, 2017 | 07:17 PM
Re: Found these seatbelt sleeves
This might be a dumb question but how are they installed over the seat belt?
Old Nov 2, 2017 | 07:53 PM
Sdallaire's Avatar
I will find out next spring. Car is already store for the cold season.
Old Nov 2, 2017 | 08:20 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Probably unbolt seat belt receiver assembly from center tunnel and slip the end plate in from the top.
I just bought this stuff, cut to length and heat gunned it. Works perfect and pretty sure it can be painted for a perfect match.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Nov 2, 2017 | 08:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The originals are secured where the small round hole is.With a sonic weld if some type, real PITA to undo, but not impossible.Once done they simply slip out from the top.
Old Nov 2, 2017 | 08:58 PM
It's nice that reproductions are available, but it stinks that they're damn expensive for such a basic part.
See the hole just above the bolt hole? If you look at the stock receivers, there's a molded divot in the sleeves around that same point. If you slip a flat screwdriver into the sleeve through the bolt hole, and pry carefully the sleeve will break free and slide right off. There's a hole in the mounting tab that the sleeve is molded into. The plastic plug that comes with the replacement pins them back in place. I suppose a pic is worth 1000 words...
Old Nov 3, 2017 | 09:18 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
To anyone that doesn't have a Gray or Black interior -- these CANNOT be dyed. I have tried several times, with multiple coats of adhesion promoter. Dye comes off immediately when they come into contact with anything, particularly if the seat is moved forwards or backwards (which it has to be to install these).
Old Nov 3, 2017 | 09:34 AM
Engine: 350 TPI L98
Transmission: WC T5
Here's a pic of the gray 3M shrink tube. It's a little light but not as bad as the pics with the flash too close. I am going to pickup a close color match touch up or bumper paint and be done. Works perfectly.
Old Nov 4, 2017 | 04:03 AM
t/aws61985's Avatar
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Hawks makes repops now.
Old Nov 5, 2017 | 01:06 PM
1992 Trans Am's Avatar
Engine: 5.0L 305ci TPI
Axle/Gears: 3.08
These are from Hawks. They’re selling them for $60 for the pair.
Originally Posted by Sdallaire
I feel lucky!!
30$
Old Nov 5, 2017 | 08:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Got a 3M PN?
Edit: thanks for the link up there.
Old Nov 5, 2017 | 09:14 PM
Engine: 350 TPI L98
Transmission: WC T5
I put the link up there
