Track and Street car build
Old Aug 9, 2018 | 11:19 PM
Camaro51's Avatar
Car: 91 RS Camaro
Axle/Gears: 9" Ford 3.70 gears, truetrac, float
Hey all im new to thirdgen. Thought id share my build with you. It started as a dream of always wanting one of the 80's IROC racing series cars. They seemed to take a good looking car and make it look better. So after finding a 3rd gen circle track late model a little out of my reach and not streetable in California. I found this 91 RS as a doner to my dream.
Old Aug 9, 2018 | 11:24 PM
Camaro51's Avatar
Car: 91 RS Camaro
Re: Track and Street car build
I found a nice early iroc fiberglass hood And the iroc fiberglass rocker skirts, and tall rear spoiler
Then got the right wheels and tires
Old Aug 9, 2018 | 11:27 PM
Camaro51's Avatar
Car: 91 RS Camaro
Got a UMI performance suspension kit with sub frame connectors
Old Aug 9, 2018 | 11:35 PM
Camaro51's Avatar
Car: 91 RS Camaro
Then it was time for some body mods. It had to look like an IROC racing series car. I found fivestar sold the nose. And with a call found although not marketed they still have the ASA Racing series molds. So i got panels.
Old Aug 9, 2018 | 11:44 PM
Camaro51's Avatar
Car: 91 RS Camaro
Clecos and tech screws are a must in fitting panels. Cant tell you how many times they came off and back on again.
Old Aug 9, 2018 | 11:53 PM
Camaro51's Avatar
Car: 91 RS Camaro
A little fender trimming to lower the car with my new UMI performance weight jacks
Old Aug 9, 2018 | 11:57 PM
Camaro51's Avatar
Car: 91 RS Camaro
Yes i left the stock fenders as a mounting point for the fenders. To me it was easier as im not doing a tube chassis nascar. Its going to be a caged car, but made to work with stock suspension mounting points to keep it affordable. And its still going to work good.
they actually got cut up a bit more than this but i didn't take photos.
Old Aug 10, 2018 | 12:08 AM
Camaro51's Avatar
Car: 91 RS Camaro
Gas door relocation in the fiberglass
Radiator ducting, brake ducts, headlight covers, and the inner 2 hood pins installed
Old Aug 10, 2018 | 12:13 AM
Camaro51's Avatar
Car: 91 RS Camaro
Some final prep before getting ready to paint
Couple hours prep the first go around. Got quicker the 2nd and 3rd time.
Old Aug 10, 2018 | 12:17 AM
Camaro51's Avatar
Car: 91 RS Camaro
Old Aug 10, 2018 | 12:19 AM
Camaro51's Avatar
Car: 91 RS Camaro
Red first
Old Aug 10, 2018 | 12:32 AM
Camaro51's Avatar
Car: 91 RS Camaro
Added black
Then clear
Old Aug 10, 2018 | 12:36 AM
Camaro51's Avatar
Car: 91 RS Camaro
Getting some side exhaust tips made to getrid of stock exhaust. Then ill add my ground effects and front wear strip on the nose.
Old Aug 10, 2018 | 12:43 AM
Camaro51's Avatar
Car: 91 RS Camaro
Ok with my new door panels you are up to date on my build. Got my Wilwood road racing brakes in, plan on starting that install on sunday. Still have a little inner fender mods to do for tire clearance at the same time. After that ill start on my new seats, then the cage. Ill post as i go...
Old Aug 10, 2018 | 06:52 AM
BigDogBob's Avatar
Car: 86 Trans Am
Engine: Carb'd LM7
Axle/Gears: Stock 2.73
Interested. Following
Old Aug 10, 2018 | 08:50 AM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Awesome work
Old Aug 10, 2018 | 08:54 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Axle/Gears: MWC 9” 3.00
Wow i like it!
Old Aug 10, 2018 | 10:19 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
car looks really cool! nice job.
Old Aug 10, 2018 | 01:24 PM
Camaro51's Avatar
Car: 91 RS Camaro
Thanks guys. Its been a lot of work. Everything you see here was started in January and went to just a couple weeks ago. Rushing through it all in photos makes it seem more simple than it was. A lot of fitment. Also a day job cuts into work time lol.
Old Aug 11, 2018 | 09:49 AM
Camaro51's Avatar
Car: 91 RS Camaro
One of the small things i forgot about. My new parking lights and turn signals.
Old Aug 11, 2018 | 09:51 AM
Camaro51's Avatar
Car: 91 RS Camaro
And my quick release steering wheel.
Old Aug 11, 2018 | 10:53 AM
Passmenow's Avatar
Car: Trans Am/IMSA GTO Camaro.
Engine: V8
Transmission: Weisman 5 speed.
Axle/Gears: Winters w/ Torsen Gleason 4.11
Man what a hot rod!
That must get a lot of looks and thumbs up!
Makes me want to build something similar, street legal with all the interior comforts.
Looking forward to more updates and photos.
For longer drives maybe some steel belted radials on whatever diameter rim required...
although big diameter rims on your vintage racer would not look as nice.
Old Aug 11, 2018 | 06:04 PM
Passmenow's Avatar
Engine: V8
Keep the rim/tires and sand off the "not".
Old Aug 11, 2018 | 06:42 PM
Camaro51's Avatar
Car: 91 RS Camaro
Originally Posted by Passmenow
Man what a hot rod!
Yeah i plan to get some street tires for it. Ive driven it to work and back a few times on the hoosiers (About 7 miles) just to shake it down. Not that it was bad, but ive noticed they dont hold air very well unless youre building heat. Not to mention a higher mileage tire would be better.
It is fun. I cant wait to have it finished to use it on the track and street. Im using it to see how much fun i have and possibly a stepping stone to more of a real race car. Ive seen some good deals time to time on circle track late models that could be reskinned as 3rd gens. but thats a decision for down the road.
Thanks for the encouragement. 😎 hope to have more to show tomorrow...
Old Aug 12, 2018 | 03:13 PM
Camaro51's Avatar
Car: 91 RS Camaro
Ok anyone know where i can find a pair of 1LE spindles? Any help would be very much appreciated. Doesnt look like they are easy to find.
Old Aug 12, 2018 | 07:47 PM
Camaro51's Avatar
Car: 91 RS Camaro
Nevermind a little search of the internet i found you cut the stock caliper mounting ears off and use the dust shield bolt holes. But i went to the junkyard and got a doner spindle to try it out on. Looks like itll work now.
Old Aug 15, 2018 | 05:34 PM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
This car is too cool! What an awesome them for s street car! I bet with that much sidewall with those 15's and that wide of stance it probably rides amazing down the road compared to some of the low pro 19" setups too
Old Aug 15, 2018 | 08:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not sure what you were asking but I have a pretty good idea. I HAD a spare set for the same reason. I had some Aeromotive brakes on the car for a few years. They used NF thread bolts to mount the bracket to the spindle. I didn't like they way they worked and put some Willwood drag brakes on. They use NC thread bolts so I had to use the 2 spare spindles I had to mount the new calipers.
I haven't been to the local junkyard in a while now. Getting harder and harder to find donor cars for parts like that. Not much left of my car that's stock anyway.
Old Aug 16, 2018 | 07:47 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Nice work I like that a lot
Old Aug 16, 2018 | 06:24 PM
Camaro51's Avatar
Car: 91 RS Camaro
well my problem was similar. i noticed the brake kit said it was made to work specifically with the factory dual piston caliper spindles. So i looked in my dealer service manual and saw there was a different spindle that the caliper mount bolted on separately. I thought to make my life easier try and find some. But those spindles are pretty much non existent. Then i did more research and found the dust shield bolt holes on my standard spindles are the correct location, but you need to hack off the stock caliper mounts. Thats why i got a doner just to make sure.
Old Aug 16, 2018 | 06:33 PM
Camaro51's Avatar
Car: 91 RS Camaro
Yeah its not bad. But i opted for the race weight coils on the weight jacks. So its a little stiff. But i also haven't tried adjusting the shocks any softer yet? Its definitely stable though. Thanks for liking the look. Its just been something i always wanted. I was going to do an all out racecar, but thought i should do one streetable first to enjoy it more. Then down the road maybe get a tube chassis car to build. First things first...
Old Aug 16, 2018 | 06:47 PM
Camaro51's Avatar
Car: 91 RS Camaro
Thanks, its a fun project.
Old Aug 17, 2018 | 05:09 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
wow,i have even more respect for this build now,damned son thats a kick a$$ car
Old Aug 17, 2018 | 07:30 PM
Camaro51's Avatar
Car: 91 RS Camaro
Thanks i appreciate that.
Old Aug 17, 2018 | 07:37 PM
Camaro51's Avatar
Car: 91 RS Camaro
These are the holes to drill and tap bigger
Mark where to cut
Cut...grind fit.
Since i was there, I had to grind the casting marks down to smooth them out. Then painted. Next... Put it all together.
Old Aug 17, 2018 | 09:08 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
so you use stock front disk brake spindles,modify them and you need to buy the adapters,calipers etc.who did you order this from?
i just installed an iroc wonderbar then i bought the umi sub frame connectors,the umi adjustable panhard,the umi adjustable
torque arm and separate mount (to get the arm off the trans tail) got all three b/n for a grand(guy bought them and found out
his car was rotten)
you need,i mean NEED a 4 speed with the straight cut gears or a tko500/600
watch this video and emulate the drivetrain in your car
Old Aug 17, 2018 | 10:05 PM
Camaro51's Avatar
Car: 91 RS Camaro
his car was rotten)
https://www.youtube.com/watch?v=pv4qouMwhj8
Well the nice guys at Wilwood sold me the brakes. They kindly told me if i really want to race it i need the road race kit front and rear. Also got their master cyl. Bought a master relocation kit off amazon since im doing it as a manual brake no power assist. But if you aren't going to race it all out you can save a LOT of money buy getting a standard kit.
be forewarned once you put the stiff torque arm with urethane bushings your rear end will whine. Not as much as the Pontiac in the video. But pretty noticeable. I like the gear whine so its ok for me. Ive got a buddy trying to sell me a Doug Nash 5 speed. But im trying to keep this car more street friendly so not sure ill do that. Ive got a small 335 race engine i built years ago on a stand crying to go in this car too. But with 12.5:1 compression i dont want to run race gas all the time. Again future projects or later evolution of this car, guess we'll see?
heres the link to Wilwood on the front brakes: https://www.wilwood.com/BrakeKits/BrakeKitSearch?year=1991&make=Chevrolet&model=Camaro&option=OE+Single+Piston+Caliper+Spindles%2c+Disc+Brake+Rear
Old Aug 17, 2018 | 10:29 PM
Camaro51's Avatar
Car: 91 RS Camaro
Another reason to not get crazy on the camaro. My dad and i are semi restoring this vintage 57 chevy late model.
Old Aug 17, 2018 | 11:14 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
that 55 will be cool with not a whole lot done to it other than basic legal stuff or are you restoring to race in a vintage class?i had a 55 Chevy a few years ago but it was pretty rough
so i dumped it to fix my 72 chevelle,that ended up needing too much so it went bye bye.now ive got my third gen and that's it,love the vintage race car ,stock car,trans am/scca look
Old Aug 17, 2018 | 11:15 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
the pontiac (in the video,bad *** car)also has straight cut gears in the trans but,the torque arm/mount really whines?it doesn't bother me much so im doing it.
Old Aug 17, 2018 | 11:44 PM
Camaro51's Avatar
Car: 91 RS Camaro
Yeah you will for sure hear the rear gears whine after you install the new torque arm. Its not a brand thing all aftermarket ones with the stiffer bar and rigid bushings do it. Just means you need louder exhaust...
And my dads chevy not really building it to race, but its really still set up to race. Just 1968 specs... Its just one of those cars my dad always wanted. So we added brake lights and headlights and mufflers to be street legal. We may repaint it in the future. But we arent over restoring it. It would be done as if ready for the next weekend.
Old Aug 18, 2018 | 01:37 PM
Camaro51's Avatar
Car: 91 RS Camaro
Pretty simple install
Old Aug 18, 2018 | 05:21 PM
Camaro51's Avatar
Car: 91 RS Camaro
Front is all put together and done. Next either the rear brakes or the master.
Old Aug 20, 2018 | 05:20 PM
Camaro51's Avatar
Car: 91 RS Camaro
I searched my emails and found the catalog page i was given for part numbers. They are limited to what they have available since this isnt a currently used body style. You need to call for price and availability. Again these are race car panels and require a bit of work to use them as i have. Fiberglass working skills are a must.
Old Aug 20, 2018 | 11:05 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
very cool project !!
Old Sep 29, 2018 | 12:36 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
very cool...
Old Sep 30, 2018 | 09:43 AM
Camaro51's Avatar
Car: 91 RS Camaro
Just to update you all whats going on. So i totally forgot these Camaro 10 bolt rears have 2 different style housing ends where the rear brakes bolt on. So i decided to save my money up and do something i was planning on doing down the road.
So last Thursday i made the trip out to Sylmar and met Kenny Sapper at Speedway engineering and picked up my Grand National rear floater kit. Cool guy and great place. If you ever get the chance i recommend you stop buy and see them.
So after that i pressed in my 5/8" studs and pressed on the rotor adapters and took them to Currie Enterprises to make me a 9" ford housing with all the Camaro brackets on it. I got oil cooler fittings and AN breather fittings for it that i gave them a drawing on where to put them.
So right now all my money is focused on the rearend. Once it comes together ill take some photos for you.
Kenny Sappers south west tour car in the late 80's at Saugus Speedway
Old Sep 30, 2018 | 03:25 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
nice,you are taking a third gen in an uncommon direction(to me anyway) and i love it.
i would love to do an scca/iroc style build sometime if i ever get to the point of being
independently wealthy and have the resources
Old Sep 30, 2018 | 06:07 PM
Camaro51's Avatar
Car: 91 RS Camaro
Well im not wealthy by any means. This is for sure a budget build for me. Its more labor than anything. Luckily i can do most if it myself. I just do little at time. Also it took me some time to get used to not having a wife that used up most my money each week. I live simple and my hobbies can get more attention. This build besides the floater rear end is fairly easy to do yourself. You can do it Bandit...
Old Sep 30, 2018 | 06:09 PM
Camaro51's Avatar
Car: 91 RS Camaro
Making longer ramps for the trailer so my dads 57 and my Camaro dont bottom out going on.
