LS3 Fuel pump recommendations
I have a stock 430 HP crate LS3 with 4000 miles on it. All new parts in the build including new gas tank and fuel pump. On the dyno, they noticed it losing fuel pressure at WOT (it’s fine just cruising). We replaced the fuel pressure regulator and determined the factory fuel lines and rail are sufficient. Going to replace fuel pump next but want to get the best quality possible so this doesn’t happen again. I see Walbro 255 as a popular choice but found this Deutschwerks DW200 that looks like good quality. What is recommended for best quality?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: LS3 Fuel pump recommendations
What pump are you running now? A Walbro 255 should work but you'll be at the upper limits of it. If you ever make more power you'll need more pump. I'd suggest a walbro 450 or an Aeromotive 340. Both of which can support around 700hp N/A.
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Aeromotive makes a stealth drop in pump/sender combo. Its what I used in my car.
Car: '90 RS
Engine: 377 LSX
So is the Aeromotive combo just the pump & sender or should there be more? Looks like there’s a 340 & a 450. Which would be best? I do plan to build up the engine after I get other things settled but that’s realistically a couple years away.
One of the guys who did the original install thinks it’s a Walbro now. Maybe the GSS341BX.
Car: '90 RS
Engine: 377 LSX
Car: 82 TA
Theres 2 pumps available, the 340L is the larger one. It's good up to 700ish hp. You can buy the sender w a tank or without. They come w spectra tanks. I used their filters and regulators as well. They use 6an lines. I have a small supercharger running 10lbs of boost and the setup has worked well.
MSRed91Camaro
Apr 14, 2010 07:54 PM
TBI89Formula
Aug 30, 2002 10:23 PM
