91 Trans Am Convertible
Car: '91 TA vert
Engine: turboLSx
Bought it from the second owner back in December of '03. I guess you could call it an xmas present to myself. Sweet. Started out as a 305 TPI Autotragic.
The owner just took a copy of my drivers license and let me take the car for the day. Wow, that's trust. Especially me being only 20.
First thing I did was start in with the suspension.
Sportline springs, Bilstein shocks, tubular adjustable panhard and lower control arms, and LCARB's.
Then I did a bunch of small stuff, a pillar gauges, 4thgen console, s2000 engine start button, ditched the stock leather seats for some more supports imitation race seats and a Momo millennium steering wheel.
Car: '91 TA vert
Engine: turboLSx
Re: 91 Trans Am Convertible
I messed with the lights a bit. Tried some cheap projector h4 conversions then some real projectors down in the bumper and have since settled with free form h4 conversions and high output bulbs. I also added clear fender lights.
I've also played with the motor a bit. Stabbed a later LT1 camshaft in, popped on an HSR manifold and Heddmen long tube headers.
Then I did the best mod ever. T56.
And then I lost third gear, first gear and reverse. So it got a rebuild along with a Pro 5.0 shifter!
Car: '91 TA vert
Engine: turboLSx
Here comes the brakes! First off it was the C5 ZO6 binders.
Along with big brakes, I had to run bigger wheels. So C5 wagon wheels here I come. 17x8.5 front and 18x9.5 rear.
Didn't take long before than wasn't enough for me. C6 ZO6 brakes! 6pot & 14" calipers.
Then I got a job at a local Chevy dealership and found some c6 wheels in the back of the parts room.
There are a lot of smaller mods I haven't accounted for, 4thgen door handles, !A/C, !Air Tubes, !EGR. Did the non-AC heater box, routed a lot of wires better, mounted a Wilwood adjustable prop valve, line lock, 4thgen master cylinder, '99 GMC Denali foglights, '96 Corvette GS-esque fender hash marks, Innovate Wideband O2 sensor, prominator and lots of messing with the tune, black "tuner" lug nuts, I've yanked the passanger side serpentine bracket off and mounted the alternator way down low on the passanger side, and lots of other stuff that I forget. Mostly smaller things that I try to aim for a "is that stock?" type of mod.
Opinions? Suggestions?
I can't say I knew the details of your car until now. I want to do a lot the same things to my car (and already have in some cases)!
'91 base Firebird verts rock!
Done any quarter miles?
EDIT: Where did you get the center peice for your Momo wheel with the Bird in the middle? I need that!
Car: 87 GTA
Ummm....What's the point of having a Starter Button, if the key switch is still there? Seems like it is more effort, to put the key in, turn it half way, then use the Starter Button, than just insert the key, and turn it to start it. Then there is the steering wheel lock issue...
Starter Buttons are neat, but with the key still having to be used....What's the point?
Car: '91 TA vert
Engine: turboLSx
Never been to a drag track, so I have no idea. Realistically mid-low 14's? I'd love to save a flat 14 or high 13 but I don't think that's realistic until I put some higher gears in it. They were 2.73s, now they're 3.23s. I need to find some 3.73s or 4.11s. The center piece is stock. I took my original one from my 87 formula and just trimmed it to fit the retainer ring on the wheel. Just another subtle mod.
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Car: '91 TA vert
Engine: turboLSx
Which ones? The ones in the bumper or the "projector" conversion in the stock area?
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Car: Pontiacs, Jeeps
Please dont quote posts with 9 pictures in them, it really sux for people with dial-up...luckily not me but I can remember those days.
iansane: I hate you...um I mean, nice car! Wish mine was half as cool. After much staring at those C6 wheels, I gotta know what size spacers or what did you need to do to fit them?
Car: '91 TA vert
Engine: turboLSx
It's a fourthgen rear with a 1" spacer. Which is too far out for the rear in my opinion. I'd like to tuck them in a 1/2" or so but I'd need to swap back to a factory rear for that. The front has a 2" spacer and the added width from the brake upgrade. If there was more upward travel in the front I would like to see a little bit wider track but oh well.
New pictures!
Not much has changed other than master cylinder which you can't see, the headers and the cleaned up brake adapters.
Cue Ball shift ball with acc button.
The wideband 'O-meter'
My hula girl!
And a really bad shot of what's going on the car this summer.
New pictures!
My hula girl!
Car: 89 Formula
Transmission: TH 700R4
Great job you have done---looks great.
One suggestion, since you asked---lose the ghetto looking ste ering wheel
Car: 1991 Formula (sold)
very cool writeup and very sweet car.
I think you have the perfect rake with the C6 wheels.
how does it ride and handle with the Sportline springs, Bilstein shocks?
Car: '91 TA vert
Engine: turboLSx
With the front springs trimmed a bit it's even stiffer.The ride is harsh. Holes and divits in the road kill me. I've vibrated more bolts loose than I care to count but it's all worth it when I throw it into the corners and the car doesn't do anything but stick to the road and go exactly where I point it. I can tell I'm getting towards the end of the usable-ness of these bilsteins. They've been on for ~five years. I'd like to try Konis now.
Yeah, it's the 18/19 combo. At a glance, to me, it looks good but the longer I look at it I want the same size front and rear. 19. They're 275s in front and 295s in rear. If they made wider tires for the 19s I would've run them but BFG doesn't.
Engine: Cammed 6.0L LSX
Very cool. I agree with you, the best mods are the kind that make people ask you "is that stock?". I've taken it upon myself to do a few of those also.
I'm envious of your T56. I'll have one some day. Until then I'm updating the front brakes with LS1 stuff to compliment my LS1 rear end. Keep us updated on the turbo.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Beautiful car you have there. Really like what you have done with it. I bet you love that rag top.
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
1" spacer on the rear with those wheels eh? I kinda like the way that looks. I was thinking of spacing my WS6 wheels another inch on the back. Either way I never knew the details on your car, and while I cant stand verts, its a beautiful car. Good work on the mods!
Car: 1991 Z28 (sold)
i dont know if you specified this, but are you sticking with the 305 for the turbo project?
the black wheels give the car a real mean look. Thats good. i wonder how it would look with chrome wheels...maybe more of a showcar look
Car: '91 TA vert
Engine: turboLSx
I'm definitely sticking with the 305. Blowin' it to bits is my goal. But hopefully that'll be after I at least acquire it's replacement, an LS* motor. I really don't know what it'd look like with chrome wheels, never been a fan of them. And haven't seen another bird like this to compare?
Car: '91 TA vert
Engine: turboLSx
Let me guess, you want this wheel don't you?
Meh, I don't see how it's a "rice" wheel, but okay. Thanks for the suggestion! I have actually been considering a new steering wheel because this is a cheap knockoff but whatever I get will be similar to this, just less silver/chrome and maybe wrapped in actual leather/suede.
Car: 89 Formula
no that one is no good either--I'll let ya know when I see one I like
Hope no ones getting upset that I don't like your steering wheel. You did ask for suggestions....other then that it's an awesome car
No harm, no foul. (Sheesh... Canadians!)
Car: '91 TA vert
Engine: turboLSx
Well, other than you being absolutely crazy... Ha! Just ribbing ya. I don't mind the comment at all. Hell, I work at a Chev dealer and get more grief about it, most think I should just sell the whole car and get something newer. Never!
Car: '91 TA vert
Engine: turboLSx
Boy, I love when you drive over dog crap. Although it happens when you've got 5 dogs.
Car: 1987 Camaro Iroc-Z
Engine: Built 355 LT1 T-Trim
Transmission: T56 6 spd
Axle/Gears: 9 bolt 3.73 gears
wow that is an amazing looking firebird, lovin the brakes
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
What a gorgous car.. damn, from humble begins to.. HOT lol
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
I love the C6 rims alot, I have been looking for wheels that look good on a 3rd gen
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
looks good , i never knew the story about this car . Just get the front fixed up and your all good , i see you have some broken gfx get them fixed it its awesome . So how was it going from the c5s to the c6's id like to do that but id need to buy some new boyd wheels.
Car: '91 TA vert
Engine: turboLSx
Thanks for the praise everyone.
Ha, no. I sold those off years ago. Whoever bought them got a SCREAMING deal. It was before I had ever shipped anything big like that and they sold on ebay for $150 + 50 shipping and it cost me almost $170 to ship them. So I basically sold the seats for $30. Shat. Live and learn I guess.
Car: '91 TA vert
Engine: turboLSx
You're damn straight. haha. I've tracked that car more than mine and it's SO much nicer. But it better be for 55k!
The GFX are broken off on both front fenders. I need to get around to replacing them.
Everyone has an ls2 but me.
